So i pulled my plugs today and i have autolite AP65 plugs..does not cross referance with anything plus they are a 14mm thread..Im told i need a champion RA8HC, N12YC or a Auto lite 4164...all of these are 12mm threads..Did the previous owner screw up ?.. Will i be able to put the proper plugs in?.. Im very concernedThe Evo motor pluig or anything that corelates to the Champion RN12YC.
:2thumbs:
Plug Manufacturer 80 CID Evolution 1984-up
Plug Gap .040"
H-D Standard 5R6A
H-D Gold 5R6AG
H-D Platinum 5R6APP
Champion RN12YC
Autolite 4265
Autolite Platinum AP4265DP2
ACCEL 2410A
Splitfire SF6D
Screamin Eagle EVS13S - Hot
EVS13P - Cold
ACDelco 44NS
NGK BPR5ES-11
NGK Platinum BPR5EVX-11
Bosch WR8D
WR8DC
WR8DP
Denso Iridium IW16
Those are right for the 04 and older engines you are fine.So i pulled my plugs today and i have autolite AP65 plugs..does not cross referance with anything plus they are a 14mm thread..Im told i need a champion RA8HC, N12YC or a Auto lite 4164...all of these are 12mm threads..Did the previous owner screw up ?.. Will i be able to put the proper plugs in?.. Im very concerned
The quoted 12YC are for 04 and earlier.
Engines went from the S&S Super Sidewinder (SSW) to the S&S Super Sidewinder plus in 05 (SSW+). For some reason they went to a smaller plug along with a few other changes cam to crank sensor and new breathing
Do you torque them John? I always just tighten by feel but am skeptical to over tighten.I like .035", unless the compression is over 11.5:1. Then I'll go to .032".
Be sure when replacing the plugs to make them tight. I can't count the # of bikes that come into my place with plugs that aren't as tight as they should be.
I tighten the new plug with a drop of oil on the threads, back off, and re-tighten them tight.
John
Update..for shits and giggles i set the plugs at .038..Big difference than .040..more power ..Tomorrow i will try the 0.35 and see how that goes.Thanks..I will try .035
