HARD TO SHIFT INTO NEUTRAL...WHY
Chopper2003
Bmarchant
I've talked to Baker, and S&S tech support. Its very common with these. I rev it a little and go from 1st to second, then pop it back to 1st, and do it one more time. Goes right in, and I get no "Bang" from the starter the next time I start the bike. Its always done it.
I've had a few really good mechanics check it out, and everything is adjusted correctly. I bought it with 10,000 miles on it, and I've now got 37,000. Its my every day ride in the summer months. It's something I now do every time, so its no big deal.
Indeed. Good explanation, but you missed the thrust bearing scenario. :2thumbs:
Once assembled, the set screw will force the clutch ramp assembly to home itself. Say no matter how the push rod is moved, screwing the adjuster screw should still move any style ramp system to its start point. So technically, the thrust bearing is being loaded upon; as it pushes the ramp assembly home. Once found, back off of the screw, then lightly seat the screw to the ramp/bearing/rod/etc. Make a 1/4 turn out from lightly seated and lock the nut. Take out the cable slack at the midpoint of the cable adjuster. Run zero gap at the lever, but still feel a slack at the cable. So 1/16th or less gap at the lever to perch.
When hot, theory is, you could spin the rod and have the clearance taken up [w/out clutch cable installed think]. Cold, you could push the rod back and forth. Ramp wise, [w/cable] you now take up the gap as the ramp rides up in the grooves, takes up the rod slack this way. You now have a hair trigger at the lever, hardly pull the lever in and the gears mesh easier when shifting. Pull the lever to the grip and N should click like butter [standing still and idling]... ONLY if the STEELS/FRICTIONS are FLAT!
T/O bearing setting sound logical?
When done, the inner clutch basket should stop as if the engine was dead = Easy N... Get it?
Viking
Biker
I get it Sven, my trust bearing went out on me on my way home from Daytona one year. Made it home with a Uhaul truck and disassembled the clutch upon reaching home. Put in a new Rod, new Cable, new trust bearing and it's good as new again.
TapioK
After my venture to Auto-clutch I happened to have 3 thicknesses of steels, open primary and too much time on my hand.
So I did spend a day playing with adjustment and steels trying different compos just for the hell of it. Now my gears go click click no matter what. I still have parts falling off occasionally so maybe I don't have enough time after all
Tapio
Hopstar
I am broke down along the road my clutch lever is slack and I cannot put it in gear to limp home... anyone have any ideas?
Sent from my SM-G935V using Tapatalk
Hopstar
It seems like my clutch is open and won't close to engage the gears I can shift but the bike acts like it's in neutral
Hopstar
It's opposite from if my cable broke the clutch would be closed and stuck in gear if that makes sense
chubs
How far from home ? push start and let off throttle to shift.
Hopstar
7 miles... it's stuck in neutral.. Clutch lever is slack but cable is not broken... it's acting like the clutch is stuck open
Hopstar
I got a tow... but now I have to figure out how to fix it.... anyone got clutch knowledge on 2005 chopper?
chubs
Doesn't sound good. Know anybody with a trailer ? No sense tearing it up any worse than it is.
Hopstar
Ya I got towed home... I can shift thru gears.. but it's like the clutch is stuck open
chubs
I don't profess to be a bike mechanic, but ya might check to see if the clutch push rod is seized up.
