The magnets do wear down. If the magnet gets worn down over time and when the distance is too much it won't allow for the electricity to generate.Hard to understand. Have never heard of one going bad. What could go wrong? Magnets get weak? How do you test for that?
That's rather an odd one...seems something else at play but won't argue with what worked for you.I also had a stator failure. As soon as the bike got warm, it would shut down. Let it cool off, and would start right up. Put everything back together and same problem. Changed rotor and all good.
?? how does the magnet wear ? there is no contact,just spins in the air.The magnets do wear down. If the magnet gets worn down over time and when the distance is too much it won't allow for the electricity to generate.
In Rick's example above I was at Strokers and his magnet was very well worn. It was the OEM rotor and Id say it probably only had about 50% of the height of the magnet when compared to the new one.
Heat too..You would be surprised when you take it off to see all the metal sludge so to speak, attached to it because of the magnetism. Just like the build up on the magnet drain plug.
Magnetic fields are effected by heat -- this scenario makes perfect sense.That's rather an odd one...seems something else at play but won't argue with what worked for you.
Why would even a bad stator make the bike quit running? You can unplug it and it will still run, until you drain the battery. But that means it was never working in the first place.Magnetic fields are effected by heat -- this scenario makes perfect sense.
Personally, If I have to replace a rotor or stator I do them as a SET, it's almost always a better bet.
DIdn't by chance get a 38A stator vs the 32A -- I know the stator/rotor combo for the 38A compufire is a little different dimensions than stock -- vaguely remember a note about space in the install instructions.Bike was not charging. Checked for AC voltage at stator and it was 0.
Replaced the stator with new compufire stator and checked for AC voltage at stator and it was still zero. . WTF?
Can rotors go bad? Their is nothing left??
The rotor was still magnetic. I don’t get it.
Well, if the regulator was damaged at the same time (in an odd method) or a really bad design and it was placing a LOAD on the electrical system you can create that failure. With our bikes EHC being soo sensitive to voltage levels its not beyond the realm of possibilities.Why would even a bad stator make the bike quit running? You can unplug it and it will still run, until you drain the battery. But that means it was never working in the first place.
Hmm, guess I now have another maintenance item, clean magnets every primary oil changeYou would be surprised when you take it off to see all the metal sludge so to speak, attached to it because of the magnetism. Just like the build up on the magnet drain plug.
Just gotta grind the bosses off the inner primary not too bad a job.So after some research, talking to Curtis@WSW @KaptinAmerika the BDM stator and rotor is a proprietary 24 coil design. The aftermarket/Harley is 12 coil.
The 12 coil rotor is larger diameter than the 24 BDM.
Looking into if it’s possible to grind out the primary to accept the 12 coil rotor. Curtis said he has done it many times so I believe it to be true. I will,update when I have an opportunity to do so.
View media item 9527BDM 24 coil stator
View media item 9526Compufire aftermarket/Harley Stator
View media item 9528Compufire aftermarket/Harley Rotor on left, BDM on right.
