Do ya have any idea where the ticking is coming from?No verdict yet aside from all of my sources telling me the wrong torque specs.. lol.. I haven' had a chance to even take the p pad off from the rally.. she is still sitting where I parked her after the rally..
What explanation of the push rods? As to why one had more thread showing then the others?? Idk.. did it 4 times which was very time consuming and got the same result every time..figured if something was wrong I would have heard it right away.. instead she fired right up and rumbledI'm still waiting on an explanation of the pushrods?
Maybe the ticking you hear is the head gasket leakSo a bit of an update, after many different responses and so on I spoke with S&S and Cometic to get a straight answer because some are saying just re use the gaskets and just re torque to many different specs.. Cometic claims they test torque specs and stress points on many different engines and assure me that I'll be fine if I use their specs which are a 5 step process which is a slow and gradual torque. They also claim that if I don' use their specs my gaskets will never seal. So I ended up speaking with an engineer at s&s and he claims I should be fine and to use their specs. So I ordered new gaskets and I will use the specs they give me when they get here and let you all know how it goes.
No sir.. it's in my rocker boxes which I have a fix for. So I should be gold when this is all said and done.. it' just a waiting game now brohamMaybe the ticking you hear is the head gasket leak
He was afraid he would break it..cant break it if it was already broke...haWait you let cdoggy ride it not running right
Oh yea! I'd send John the bill!Blame Cdogg if it exploded, brilliant
There not, well not supposed to be, but if they were he would have valve damage.When you pull the pushrods see if they are all the same length. I'm curious
He installed them here originally had the quickee Rods so 2 long and 2 short.When you pull the pushrods see if they are all the same length. I'm curious
Is this your first S&S rebuild?So just an update, used a torque wrech to loosen the bolts to verify my torque which I did after I torqued them originally.. torque wrench set at 36 didnt snap once loosening the bolts up. One was finger loose. Gaskets not blown, just all leaking badly.. as far as the push rods go, the front intake was threaded less then the rear.. no one knows but it ran great for 100 miles, still ran great when I took her apart.. just leaking oil.. lol.. I'll throw the push rods in in the morning and do the adjustments and keep y'all posted
Hahaha! I putted it round da block, the only thing I can get blamed for is going to slow!Blame Cdogg if it exploded, brilliant
Yeah, my first rebuild and actually very very east.. just should have followed my instincts on torque specs is all.. next time I'll fallow my gut for sure.. being an ASE mechanic for many many years I knew better to increase the torque in slower increments to crush metal gaskets to actually seal.. I'm sure u will be just fine. The know how was well worth every minute and the power will be well worth the money..Is this your first S&S rebuild?
I am considering rebuilding the 107 , but the motor is one thing I don’t have experience on and really don’t want to f it up. I have tore a few down to the pistons but had a shop finish it. Just wondering on the difficulty?
