Michael rogers
Went to get a sticker horn doesn't work
Sent from my SM-G965U using Tapatalk
Not yet first thing tomorrowHave you pulled the side covers to check it
If you have a volt meter I'm pretty sure the horn is 12 volts.Not yet first thing tomorrow
I'll have to test it tomorrow I hope its something easy to fixIf you have a volt meter I'm pretty sure the horn is 12 volts.
I might have to get oneI replaced my horn three times. Handlebar button/contact was the culprit. Curtis fixed me up w new board.
Thank youDonna and Derek have the horn
+1 (620) 257-2009
If it's the PC board, I can fix it for you.Thank you
Ya those button switches get debris in them sometimes from wear I guess. There not cheap either.I replaced my horn three times. Handlebar button/contact was the culprit. Curtis fixed me up w new board.
Morning Mike, If it is in fact your left control board I might have a spare on the shelf.I might have to get one
Thanks I'll let you knowMorning Mike, If it is in fact your left control board I might have a spare on the shelf.
I tested the horn, the horn is good so the switch must be junkThanks I'll let you know
If Donna or curtis wont sell you just the left noard, let me know.I tested the horn, the horn is good so the switch must be junk
