boydog
2006 k9 torque specs
anyone has this layout for a 2006 k9 that i can get ? thanks in advance
Thanks for the legwork Lee.:flag:
Here's the list, alphabetized for quick reference.
Torque specs
Air cleaner to carb 10-12 ft-lbs
Air cleaner to head bolts 8-12 ft-lbs
Ball ramp cover bolts 35-40 in-lbs
Brake caliper mount bolts 25 ft lbs
Brake rotor mount bolt 50 ft lbs
Cam cover bolts 120 inch-lbs
Carb to manifold bolts 18 ft-lbs
Engine drive sprocket nut 150-165 ft-lbs - red loctite
Exhaust flange bolts 60-80 in lbs
Forward control mount 25 ft lbs
Front axle 45 ft lbs
Front axle pinch bolts 12 ft lbs
Inner primary bolts 15 ft lbs
Inspection cover bolts 9 ft lbs
Intake flange bolts 16 ft-lbs
Lower triple tree pinch 16 ft lbs
Motor mount bolts 35 ft-lbs
Neutral switch 10-15 ft-lbs
Outer primary bolts 9 ft lbs
Primary fluid 32 oz
Pulley cover bolts 18-20 ft-lbs
Pulley nut 50 ft-lbs + 40 degrees
Rear pulley bolts 60 ft lbs
Rear axle 55-65 ft lbs
Rear fender strut bolts 25 ft lbs
Rear shock mount bolts 100 ft lbs
Spark plugs 18 ft-lbs
Tappet screen plug 120 inch-lbs
Transmission drain plug 7-9 ft-lbs
Transmission main / clutch hub shaft nut 80 ft-lbs - red loctite
Transmission mounts 45 ft-lbs
Upper engine mount to cylinder 35 ft lbs
Upper engine mount to frame 45 ft lbs
