03 Chopper: spark and fuel, no start.
Discussion in 'Technical' started by PUBKEEPER, Mar 2, 2016.
  1. PUBKEEPER
    PUBKEEPER Member
    Colorado Springs, CO
    03 Chopper
    Krueger
    Howdy all. After searching for 2 days, I can't find a thread with the same issues I am having. Getting good fuel, good spark, turns over, won't fire. I had the battery load tested and it's good, 500 cca. Not sure where to go from here, any thoughts?
    chubs likes this.
  2. chubs
    chubs Guru
    Full Member
    indiana
    2002 pitbull Prostreet --
    runky
    :oldconfused: timing? :oldconfused:
    dentdude36 likes this.
  3. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    What do the plugs look like? Have you flooded it?
    dentdude36 and chubs like this.
  4. PUBKEEPER
    PUBKEEPER Member
    03 Chopper
    Krueger
    It's not flooded, I pulled the plugs(less than a year old), cleaned what little soot was on them when I verified spark, and they weren't wet. Seems like a timing issue Chubs, but why would that suddenly change with the bike sitting for maybe a month since last start?
    chubs likes this.
  5. 05chop
    05chop Well-Known Member
    wyoming
    05 DT Chopper & 2010 Street Glide
    Do a quick spark plug change then do a compression test with a gauge or rubber tip air gun.Could have to heavy of motor oil
    PUBKEEPER and chubs like this.
  6. PUBKEEPER
    PUBKEEPER Member
    03 Chopper
    Krueger
    I'll give it a shot tomorrow and get back. What weight do you run?
    chubs likes this.
  7. 05chop
    wyoming
    I live at 6200 feet still cold up here just remember your motor should spin really fast so I run mobile one 20-50.Do the easy stuff first
    PUBKEEPER, chubs and dentdude36 like this.
  8. Marky-Marc
    Marky-Marc Well-Known Member
    Full Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    Fuel, spark, air and you have all of them...are you testing spark AT the spark plug or at the END of the spark plug wire?
    chubs likes this.
  9. Marky-Marc
    Full Member
    Des Moines, IA
    Marc
    @PUBKEEPER, did you change your oil? Reason being, the crank sensor is next to the oil filter...make sure it's on TIGHT! If you pushed or wiggled it a little while taking oil filter off, bike won't start...keep it simple brother.....
    Here's a link to a photo of the crank sensor...hope it helps...but if you have air, fuel and spark...it's could be your crank sensor, either wen't bad or connector is loose....
    http://www.bigdogbiker.com/threads/good-coil-no-spark-to-the-plugs.33108/
    #9 Marky-Marc, Mar 2, 2016
  10. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    How old is the gas and when was it last running? The spark plugs are wet with gas correct?
    chubs likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    He said it was running a month ago
    francoblay1, dentdude36 and chubs like this.
  12. Little-Boo
    Little-Boo Well-Known Member
    Lifetime Supporting Member Troop Supporter Supporting Member Full Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    Marky the 03 don't have a crank Sensor. They have a cam timing sensor of some type located on the cam cover. I have never worked on one so I just watch from the side lines :oldlaugh:
    Carlos :eek:
  13. FrankBDPS
    Full Member
    North Lawrence,Ohio
    Frank
    Carlos is correct. The 107 did not use a cam sensor. If the bike was running a month ago it has got to be something simple. To me if you have a good strong spark I would look for a fuel issue.
    chubs likes this.
  14. chubs
    chubs Guru
    Full Member
    indiana
    runky
    :oldthumbsup::oldthumbsup: Good point Frank. How do we know that it's getting fuel to the cylinders? Maybe try pullin the plugs out and giving each cylinder a small shot of gas, put the plugs in and see if she fires? That might narrow things down a little bit, but I have no clue how to check if fuel is getting through the carb. Just a thought. :oldconfused:
  15. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Take the air cleaner off, and look inside while you twist the throttle. You should see the gas squirting into the intake if gas is going through the carb.
    chubs likes this.
  16. chubs
    chubs Guru
    Full Member
    indiana
    runky
    DOH ! :oldcrazy: I told ya I aint the shiniest spoke in the wheel ! :nonod: I shoulda known to do that !!:yesnod:
  17. Marky-Marc
    Full Member
    Des Moines, IA
    Marc
    Good to know bro....never worked on one either, but either way, crank sensor or timing sensor, if it were out, it wouldn't turn over correct? I am now correcting myself...hahahahaha
    chubs likes this.
  18. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    chubs likes this.
  19. chubs
    chubs Guru
    Full Member
    indiana
    runky
    I'm probably wrong here Marc, but, I believe it would turn over. If it was one of those sensors, would the coils fire? Would it fire the coils, but at the wrong time? :oldconfused: I'm thinking you're a lot smarter than me, so I'll go with whatever you say! :cheers:
  20. chubs
    chubs Guru
    Full Member
    indiana
    runky
    :hi: Shouldn't it crank over, but just not have spark? :oldconfused: Or would it have spark at the wrong time? :oldconfused: I'm starting to lean more towards a fuel, or lack thereof, problem.:skep: ( I really hope it's not something like I did, when I had the fuel valve in the wrong position! The cost of education keeps going up!! :crazybitch: )
