04 pitbull to ridgeback build
Discussion in 'General' started by pauldeepsea, Aug 13, 2017.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That is one sweet looking wheel:old2:
    PacoPetty likes this.
  2. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    Okay so I got the controls mounted and have a bit of a gap. I don’t remember having a gap like this on the pitbull.
    Thoughts or do you have any pics on your hand control fitment?
    I am concerned with water getting into the boards
  3. Brandon Downey
    Brandon Downey Active Member
    Full Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    I'm pretty sure you did, but did you remove the powder coat from the area?
    BWG56 and chubs like this.
  4. pauldeepsea
    Full Member
    California
    Paul
    Yes as much as I could without it showing past the controls [​IMG]
    chubs likes this.
  5. pauldeepsea
    Full Member
    California
    Paul
    Forgot to mention these are bars that came with the frame not sure what big dog they go to but the pull back allot further making them easier to reach
  6. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    that is NOT how mine are. believe that little bit of p/c is keeping it from closing up.
  7. Brandon Downey
    Full Member
    Anderson, IN
    Brandon
    I agree that the powder coat is the problem. I can't remember how much it adds in thickness, but the proof is in the fact that the hand control is all the way together on one end and gapping on the other.
  8. Brandon Downey
    Full Member
    Anderson, IN
    Brandon
    Probably fix it by removing the hand control and observing exactly where the control makes contact with the bars and removing that tiny little bit more.
  9. Brandon Downey
    Full Member
    Anderson, IN
    Brandon
    Btw I am really enjoying following this build of yours so thanks for sharing!
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Markey Mark chromed his so it can be done.
  11. Th3InfamousI
    Texas
    Before powder coating which can be a problem.....try angling it differently meaning move the whole setup up and down. If it's not perfect it never fits right. I've seen that gap before and it was control board was too far up and needed to be angled down, which then brings the clutch lever up higher
  12. pauldeepsea
    Full Member
    California
    Paul
    I have tried that, I have some ideas. I am thinking about getting some carbon paper or chalk and wrapping it around the bars putting the controls on to see where it’s making contact and grind that area down
    More to follow
    Rottweiler and chubs like this.
  13. pauldeepsea
    Full Member
    California
    Paul
    Well I got, I used black touch up paint on the insides of the controls and mounted them to the bars. I removed them and used my dremel to remove any powdercoat that had black around it. It created a nice outline. It closed the gap, not completely but I am comfortable with it.
    PacoPetty, Hirter6Pack and chubs like this.
  14. Brandon Downey
    Full Member
    Anderson, IN
    Brandon
    Awesome! And they all thought I was wasting my time watching American Chopper but I was learning!
    PacoPetty, SCOTTx88 and dentdude36 like this.
  15. pauldeepsea
    Full Member
    California
    Paul
    Build update:
    Docs esc shipped today.
    Motor is about two weeks out decided to rebuild both cylinders due to the parts already ordered. Probably only a few hundred miles on the motor but might as well do it a save on the labor.
    Should have the wiring harnesses and drive train installed within the next month. And per Doug will post photos of the build.
    Also just picked up this electronic torque wrench for Xmas [​IMG]
  16. pauldeepsea
    Full Member
    California
    Paul
    Started installing docs esc today. Really impressed with his setup.
    Engine should be back together this week. May have to slow down on the build due to no paycheck thanks to the government shutdown. Working for free this week... [​IMG][​IMG]
  17. Th3InfamousI
    Texas
    You don't like working for free? I'm sure it won't last long and you'll get the back pay anyways.
    ESC is a very nice unit well put together and nicely heat shrunk everywhere.
  18. pauldeepsea
    Full Member
    California
    Paul
    Esc mounted, so far going good. [​IMG]
    PacoPetty, bdm7250 and Unsprung like this.
  19. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    ESC is definitely the best choice,:old2: it won't let you down. Looking good Paul.
    PacoPetty and BWG56 like this.
  20. pauldeepsea
    Full Member
    California
    Paul
    Man this thing is so much easier than the wp install. I did manage to pull one of the jst pins out and will need to re chrimp a new pin. But the install is a breeze. Very impressed with the unit
  21. pauldeepsea
    Full Member
    California
    Paul
    Last one Tonight, trying to figure out where I am going next with the project [​IMG]
