05 pitbull Loud screeching noise from primary
Discussion in 'Transmission / Drive' started by Nate Smith, Oct 7, 2018.
  1. Nate Smith
    Nate Smith New Member
    Big Dog Chopper
    Naste
    Looking for advise.... First let me introduce myself to the Big Dog Community My name is Nate and I just bought my big dog about 4 months ago I have an 05 Pit bull 117CC And 6 speed Baker transmission.... So Now my question. I've been getting the loud screeching noise from the inside of my primary. So I took the primary Cover off in seen the the chain was loose also seen that the chain is hitting the inside of the outer primary cover.... So thinking that the chain was my problem I just Tighten it... But i'm having same problem.... any ideas
    francoblay1 likes this.
  2. Steven Proctor
    GA
    '06 K9, '03 VTX1300R
    Steve
    Welcome to the forum from SE Ga. I am not sure, as I have an open primary. Do you have any pix? I recommend doing a search for this. Lots of great advice and How 2's.
  3. Billy the kid
    Billy the kid Well-Known Member
    Gunnison colorado
    Bigdog Ridgeback 2006, 2010 Harley CVO ultra electra glide
    Your clutch hub nut has probably come loose
  4. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    Sure sounds like something came loose. Id you need a complete primary i still have all the parts that came off my 07 K9 when i installed the baker open primary.
  5. Fat_Bastard
    Fat_Bastard Active Member
    Route 66
    2004 Big Dog Chopper, HD Fat Boy
    Title: "CRO" , Chief Riding Officer, SoCal riders group
    More than likely loose compensator nut and/or bad/broken compensator spring. That was the case on my 04 Chop... But also could be what others have said...
    francoblay1 and HMAN like this.
  6. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Welcome and good luck with your repair
  7. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    You may need to adjust your primary chain tension
  8. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    Nate, your best bet is to pull your primary cover back off, check your clutch hub nut, sprocket nut, maybe even remove the clutch basket and have a look at everything and clean it. After checking everything, reassemble with correct torque specs and loctite. Did you see any shavings in the primary? On the primary drain plug? Are all 6 of your transmission bolts still in? Where were the markings on the inside of your primary cover?
    Post some pictures of the primary cover markings or of the inside of your primary...someone may just notice something that's not right.
    Billy the kid and chubs like this.
  9. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    there was a redesign of the clutch carrier around late '07/'08 due to cracking. would certainly be a good idea to remove the clutch and check that for problems. could be the carrier scrubbing on the inner primary.
    Billy the kid likes this.
  10. KnotSo
    KnotSo Admin
    Washington
    What was the issue?
  11. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Check THIS out. :oldthumbsup:
    :chopper:
