05 ridgeback carb
Discussion in 'Technical' started by Mike manson, Dec 5, 2017.
  1. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Don’t know anyone who is using enricher really. Let the bike warm up a minute or two before riding. You might carry a small screwdriver or a pocket knife in tour pocket to adjust the iddle a bit higher or lower when needed. Both my Dogs (107 and 117) stay idling pretty good without any help even cold, I think my idle is around 900 rpm
    chubs likes this.
  2. Unsprung
    Ruskin, FL
    Gerald
    When starting bike cold it will sometimes idle lower than normal, keep idle speed up with throttle if needed until it’s warm. A few times on startup my rpm lights actually flash indicating idle is two low. I use the throttle to keep it at 1000 and it maintains speed once warm. I’ve never used the enrichener on my K9 but that is not the case for all.
    BWG56 and TapioK like this.
  3. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    I also have never used the enrichener, starts and idles fine hot or cold. May need to keep tuning or clean the jets in carb
    TapioK likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I use the enrichener to start the bike then immediately turn it off and use the throttle, wife gets on and we take off. I keep the RPM's under 2000 for the first 5 miles. I've never left it idle for minutes.
    pauly likes this.
  5. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    Punctuation would be a good start.
    francoblay1 likes this.
  6. No H2O
    No H2O Active Member
    DC
    2004 Ridgeback, 2004 BMW R1150r, 2001 Fat Boy
    Mark
    FWIW I talked to my mechanic about this today. He said the 5 minute warm up to get to no enricher/choke needed is expected and if I wanted to ride sooner, I could ride with the enricher/choke on and gradually back it off until it's completely off with no adverse effects.
  7. MossBerg590
    Arizona
    Tyler
    I think that's just a generic response. Like I said I have never used my enrichener on my ridgeback and it starts and idles fine, even after not starting it for a few weeks. Over time I'm sure you will get it dialed in, as long as your enjoying it mean time..thats what matters
    Coolbreezin, chubs and Unsprung like this.
  8. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Piece of Cake, three twist of the throttle and off I go after a couple mins at 1500 rpm (cruise-mate).
  9. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    And there you go!
