06 Mastiff has ticking noise on the forward jug
Discussion in 'Help Wanted' started by tatajoe, Jan 23, 2018.
  1. tatajoe
    tatajoe Member
    Douglas Arizona
    06 mastiff, 2010 HD Road Glide
    Jose
    Bike has ticking noise on the forward jug and back fires at de-accel, S&S folks say its some bushing on valve train and sent me smaller primary jets. i have adjusted the push rods to specs added a new thunder bolt ignition. Haven't changed the jets yet but wondering if i should go on and open the top end also would you have the gaskets I'll need and the bushings they,re talking about
    chubs and Reddickracing like this.
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Before you do that, check to see if you have an exhaust leak, and check the compression release. Either one of these will make it sound like a rattle in the top end.
    john sachs, chubs and Butch Cassidy like this.
  3. tatajoe
    tatajoe Member
    Douglas Arizona
    Jose
    Thanks Guru, did those checks last night. Cleaned out all connections for good grounds as well. Guess i"m back to opening the top end. Gotta order the gaskets and see about the bushings, hopefully it'll be that and no further tearing down.
    chubs likes this.
  4. Butch Cassidy
    Butch Cassidy Active Member
    Fate Texas
    2000 Bulldog
    BUTCH
    ...before you bust that top end... take an oil analysis, that might help make your decisions
    Blackstone-labs.com
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    The bushings they are telling you about is the rocker arm brass bushings. Now the bushings are cheap however the problem is to ensure they are fitted correctly they need to be reamed to the right size. The reamer alone is $200. Might end up being easier to remove them and have the shop install them and ream them if you got a good shop in your area.
    Here is the reamer:
    http://www.vtwinmfg.com/webapp/wcs/stores/servlet/VTwinProd1_10101_10102_3295747_-1
    Now if your going that far is also replace the rocker arm shafts because if bushings are worn it may wear the shafts. You gotta take the shafts out anyways and they are cheap so really no point in not replacing.
    https://www.amazon.com/Cycle-Rocker-Arm-Shaft-Set/dp/B000GU27UU
    chubs likes this.
