1999 Pro Sport
Discussion in 'Vintage Big Dogs' started by mypup, Feb 23, 2017.
  1. mypup
    mypup New Member
    Kansas
    2006 Pitbull
    Mike
    I need to replace the rear shocks and need some advice on what is available for my old dog. Thanks in advance. I also need to replace the left gas cap.
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    Navarre,Ohio
    Frank
    Mike, you're shocks may be rebuildable. If they are like mine they can be sent back to the factory and rebuilt. image.jpeg
    mypup and chubs like this.
  3. mypup
    mypup New Member
    Kansas
    2006 Pitbull
    Mike
    Thanks for the reply. The previous owner told me that he just rebuilt them but the are leaking. The "Harley shop" tech stated that he didn't think they could be that they are just wore out and to check drag specialties. Anyone know where I might get a set?.
    chubs likes this.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    You got an older dog Should be any shock for a Harley softail late 80 early 90's that you fancy should work.
    A vendor on here sells some too
    http://www.wildsteedworx.com/index....ucts_id=1326&zenid=sk6kneckbtfgbfdo9ncs8r2rk5
    chubs and mypup like this.
  5. FrankBDPS
    Navarre,Ohio
    Frank
    If you're shocks look like mine don't throw them away. Send me a picture of them. I might be interested in them.
  6. mypup
    mypup New Member
    Kansas
    2006 Pitbull
    Mike
    chubs likes this.
  7. Th3InfamousI
    Texas
    Don't know for sure. Frank is the man with the older dogs.
    I'm certain any similar Harley softail shock that looks like that will work though. Just get the right length
  8. FrankBDPS
    Navarre,Ohio
    Frank
    I never saw a shock like those. They look expensive. Give Wildsteedworx a call or email. Curtis should know what would work.
  9. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2008 HD Fatboy
    Rick
    These are just like mine (i.e. Frank's). They are Works Performance shocks. http://www.worksperformance.com Pretty sure one could get on the phone with them and they would walk you through how to size them.
  10. HellOnWheels
    HellOnWheels Member
    1999 Vintage Sport
    Father
    I used a set of Progressives on my Vintage Sport, but any set made for an FX-series Harley should fit provided you get the proper length. Don't do like I did and get a set that's too short, you'll piss yourself off when you have to buy that new rear tire!
  11. luxurious575
    luxurious575 Member
    Las Cruces, NM
    2000 Big Dog Pro Sport
    Zach
    I need shocks as well. I don't like the painted spring. 17264489_10212207698975654_7939438005004882694_n.jpg
    chubs likes this.
  12. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    I know this is an older post but are these shocks mounted upside down or is it just me.
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Definitely easier to adjust that way
    chubs likes this.
  14. Th3InfamousI
    Texas
    Not all shocks are meant to be mounted upside down. Looks like its right side up to me. However having the adjuster on the top is kinda an eye sore.
    chubs likes this.
  15. pknowles
    virginia
    paul
    And the 2 adjusting nuts and bare threads aren't, just an opinion.
    chubs likes this.
  16. Th3InfamousI
    Texas
    ? Huh? Yes I agree the whole adjuster on the top is an eye sore including the bare nut/threads
    chubs likes this.
  17. pknowles
    virginia
    paul
    The tension adjuster is on the bottom in the picture. The ride height is on the top/ I just thought they were upside down. I put my burly shocks on the streetglide in the opposite orientation.
    chubs likes this.
  18. Th3InfamousI
    Texas
    Sorry...think my comment was confusing.
    Yes..I do think it's upside down as well.
    I was just mentioning that some shocks are meant to be mounted upside down. These probably are fine to mount upside down.
    chubs likes this.
