2001 Wolf Speedometer
Discussion in 'Vintage Big Dogs' started by Chuck Hughes, May 7, 2018.
  1. Chuck Hughes
    Chuck Hughes Member
    Bechtelsville PA
    01 Big Dog Wolf, 02 Chopper Sportster
    Chuck
    Hey guys, is there a way to replace the lights inside the speedometer or does the whole thing speedometer have to be replaced? Just noticed the other morning riding to work that the lights weren't working.
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    Chuck, if all the lights quit working at the same time you may have a broken wire or bad connection someplace. If you take the dash apart handle it with care. They are thin fiberglass and are no longer available. Check the plug on the back of the speedometer. It needs both a hot and a ground running to it. Good luck.
    Chuck Hughes and chubs like this.
  3. Chuck Hughes
    Chuck Hughes Member
    Bechtelsville PA
    Chuck
    Thanks Frank. That last sentence in my original post was supposed to say the running light isn't working either. I still have brake light, and headlight, but I noticed my turn signal automatic shutoffs arent working either. I have to manually turn them off
  4. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2004 HD Fatboy, 2008 Jeep Rubicon, 1972 VW Bus
    Rick
    Frank is right about the pin connector into the back of your speedo. It is a five wire pin that includes power and ground and a pair of wires going to your transmission sensor carrying signal there and back (I believe the 01 Wolf would still have the same setup as my 2000 Vintage Classic). The other wire talks to the relay circuit in your Thunderheart Module that acts as a traditional flasher relay. Before you overthink any of the electronics, check the condition and connection of all five of those wires. The light, on the other hand, in your speedo could be a broken solder point on the speedo circuit board has several potential causes - one of which may be a poor connection of the power wire in the said five pin connector. Start there. Do you have the Dakota Digital VDO speedo?
    chubs and pknowles like this.
  5. Chuck Hughes
    Chuck Hughes Member
    Bechtelsville PA
    Chuck
    This is the speedo I have. My lighting issues have been fixed, except for the speedo light. Really don't wanna have to replace the speedo, cause that will change my mileage reading.
    chubs likes this.
  6. BigDogRick
    Phoenix, AZ
    Rick
    Mr. Wright has been known to fix lights in speedos that simply had a soldered diode come loose on the circuit board. I don't know if he has done one of these VDOs (that's what you and I have). Its programmable and has a nice calibration feature. But I would really check the five pin connector in the back for an easy trouble shoot.
    chubs likes this.
  7. Chuck Hughes
    Chuck Hughes Member
    Bechtelsville PA
    Chuck
    I did check the 5 pin connector, but even if it was that, wouldn't it affect more than just the light? Would the whole speedo not work properly?
  8. BigDogRick
    Phoenix, AZ
    Rick
    I have had just one pin come loose a couple times.
    Sent from my iPad using Tapatalk Pro
    Chuck Hughes likes this.
  9. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
