2003 107ci wont start
Discussion in 'Technical' started by virgil, Dec 7, 2017.
  1. virgil
    virgil New Member
    Jacksonville FL
    03 mastiff 107 Big Dog
    Virgil
    what i know and whats been done.
    New 3.0 Dyna coil installed this year ran after install.
    Sat for 6 plus Had hip replaced
    wire checked red wire to coil insuring voltage presents 12.3
    wire checked blue wire from coil to plug 26 ohm 0L 0.0
    yellow lite on BD4121-1D flashes during start attempt red light bellow does not illuminate during start attempt or pwr on.
    Red light on start module 170-00251 flashes during start attempt.
    a know good coil and wires were slaved in with no start.
    No fire to coil
    Plugs were also changed from a running bike.
    So which item do i buy the 170-00251 or the BD4121-1D? Or Both?
    chubs likes this.
  2. HMAN
    HMAN Just like to ride
    Supporting Member Full Member
    Ks
    Harry
    Have your battery checked/replaced. Welcome from Kansas.
  3. Unsprung
    Full Member
    Ruskin, FL
    Gerald
    Have you checked your cam sensor in the nose cone?
  4. chubs
    chubs Guru
    Full Member
    indiana
    2002 pitbull Prostreet --
    runky
    Ignition module ?
  5. virgil
    virgil New Member
    Jacksonville FL
    Virgil
    Tried that didnt help but thanks
  6. virgil
    virgil New Member
    Jacksonville FL
    Virgil
    not yet how would that eliminate fire to the coil?
  7. virgil
    virgil New Member
    Jacksonville FL
    Virgil
    thats what im thinkin
  8. virgil
    virgil New Member
    Jacksonville FL
    Virgil
    thanks will do new to the site how do i search for that particular test?
    V
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  10. Unsprung
    Full Member
    Ruskin, FL
    Gerald
    I had a similar issue on my 03 Pitbull. The cam sensor was burnt, could actually smell it when the nose come was opened. Also needed an ignition module when my voltage regulator went on the lam, but that’s a different story. I know when testing your coil the procedure is not cut and dry and will post it if I can locate it.
  11. Unsprung
    Full Member
    Ruskin, FL
    Gerald
    Coil check/Spark
    You don't measure it to ground! Disconnect all the wires on the coil then one meter lead goes on the (+) and the other lead goes to the terminal where the yellow wire was and then to the terminal where the blue wire was. Both measurements should be 2 - 4 ohms. That's the low tension test.
    For the high tension test all you do is put one meter probe in each spark plug wire hole. The reading you get should be 12K-21K ohms.
    If those tests are good and you have a good 12VDC to the coil you may just have bad spark plug wires
    dentdude36 likes this.
  12. virgil
    virgil New Member
    Jacksonville FL
    Virgil
    Thanks, did the test as you wrote and found high resistance in the wires just as you said ....so got one ordered up will let you know.
    Virgil Florida
    bdm7250, BWG56 and dentdude36 like this.
