2003 BDM to ThunderHeart Module Conversion
Discussion in 'Technical' started by Night Train, Jul 7, 2010.
  1. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
  2. liferider
    liferider Guru
    Louisiana
    Jonathan
    Just installed one, had to put a relay though from the ignition.
    chubs likes this.
  3. Samson
    Samson New Member
    2003 Big Dog Mastiff and 2009 Harley Ultra Classic
    TY for the link Kaptain Amerika. Pulled the trigger on the Thunderheart kit. Also went ahead and got the kit that adds a relay for teh starter as an option to keep the module from heating up.
    chubs likes this.
  4. brandoniron10
    brandoniron10 New Member
    03 bigdog pitbull
    Brake lights
    My 03 pitbull brake lights quit working, I have turn and tail lights still, have a service manual and followed the trouble shooting and it states that the ehc is bad, dies anyone know if the BD4030-1B is still available or do I need to do the conversion to the thunder heart ASM4250 that night train posted
    chubs likes this.
  5. KaptinAmerika
    2006 Big Dog K9
    Curtis
    If you have the BD branded EHC then you will either have to find a used BD EHC or you will want to go with the Thunderheart conversion kit, made by WSW. It converts your BD EHC back to a Thrunderheart EHC which is what BD was using up until 2002.
    BD EHC to Thunderheart conversion kit
    chubs likes this.
  6. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2004 HD Fatboy, 2008 Jeep Rubicon, 1972 VW Bus
    Rick
    I will sure vouch for the Thunderheart. 15 years and still running strong on my 2000 Vintage. I have replaced nearly every electrical component on my bike, many with spectacular failure (y'know, flames, pops, fizzles, and stranded in BFE) and the module just keeps on ticking.
    chubs likes this.
  7. boostlife7
    boostlife7 Member
    Everything works great but my turn signals work but not the lights on the dash indicator
    chubs likes this.
  8. racedaze98
    racedaze98 Member
    Warrenton, Missouri
    2003 Big Dog Chopper
    Tony
    I have now had 2 BDM EHC modules go out. I purchased a Thunder Heart module and wiring kit (ASM 4250-D). I have a BDM Module diagram and I have printed conversion instructions from this thread. My question is ... Is WSW's wiring kit already set up for conversion or is it the same harness that came in my kit.
    chubs likes this.
  9. KaptinAmerika
    2006 Big Dog K9
    Curtis
    WSW's kit is made to convert accurately and without allot of issues.
    It is not simply the harness that comes with TH's module when you buy their kit.
    We also make the harness with a secondary relay for the starter to take the load off the module.
    We don't claim to have the market cornered on this conversion.
    We have simply taken the guess work out of it for those who are looking for the easiest way to convert and would like tech support available if they do run into issues.
    Unsprung and chubs like this.
  10. racedaze98
    racedaze98 Member
    Warrenton, Missouri
    Tony
    I printed Night trains instructions for the conversion to a Thunder Heart Module. I'm down to the last step and it says to add new wires from pin 14 & 15 to the ignition switch. Is it talking about the keyed switch or the start push switch? Which wires can be tapped into to complete this?
    chubs likes this.
  11. Unsprung
    Ruskin, FL
    Gerald
    I've wired WSW's TH kit on my 03' Pitbull and it was a nice simple install with great instructions and even better tech support. Curtis has taken the guess work out of the conversion and answered every email question I had.
    chubs likes this.
  12. racedaze98
    racedaze98 Member
    Warrenton, Missouri
    Tony
    Well..... I finished the conversion last night. All the light now work and the engine started and ran perfectly. !0 minutes later I went to start it again and all I hear is the starter solenoid click. I checked the wiring harnesses to the new module and checked voltages to the starter. I have 12.3V going to the starter and 6.5V going to the solenoid. Does anyone know what the solenoid voltage should be ? This is becoming typical for this bike.
    chubs likes this.
  13. KaptinAmerika
    2006 Big Dog K9
    Curtis
    12volts
    dentdude36, chubs and racedaze98 like this.
  14. racedaze98
    racedaze98 Member
    Warrenton, Missouri
    Tony
    I have 6.5 on that circuit and don't know why
    chubs likes this.
  15. KaptinAmerika
    2006 Big Dog K9
    Curtis
    Do you have any LED trouble lights on the Thunderheart module?
    chubs likes this.
  16. No H2O
    No H2O Active Member
    DC
    2004 Ridgeback, 2004 BMW R1150r, 2001 Fat Boy
    Mark
    If the Thunderhearts were standard on all 2002 and earlier BDMs, then mechanically (not necessarily asthetically) it makes most sense to buy a 2002 or earlier...?
  17. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    Not sure what you are actually asking? There are plenty of electrical parts for these bikes (at least at the moment). Put your pennies in a jar for the day when you need something fixed. Face it these bikes are not mass produced HDs or Yamaha with R&D and Test depts. They where "custom" bikes. They will break and you will need to fix something. There are a lot of older dogs that folks did not take care of and you will spend a fortune fixin stuff. It is just the way it is. I like my 04 Chopper. I spent a lot of time and money fixing crap. It's fun as hell to ride. I have a Roadstar, its reliable but even that bitch left me on the side of the road. I have had to fix electrical issues on it as well. If its electrical or mechanical it will fail eventually.
    chop it likes this.
  18. No H2O
    DC
    Mark
    Ok so if I wanted zero headaches I'd buy a second BMW r-series, no maintenance on that bike will even take up an entire afternoon much less a day and the only time it's down is when I catch a nail while riding the shoulder.
    I think we're all here for the same reason and that's the driving experience. You get on a chopper and realize you have to have one.
    With that said, I'm expecting to do some wrenching, I'm just trying to minimize the headaches and be on the road more than in the garage.
    chubs likes this.
  19. KaptinAmerika
    2006 Big Dog K9
    Curtis
    Well thanks to Electronik those with the 03 style BD EHC no longer have to fret.
    WSW is releasing the Electronik 03 Plug N Play EHC replacement on Monday 05/07/2018.
    If your start module is shot or you just want to get rid of it all together WSW will have an accessory harness available for that purpose.
    pknowles likes this.
  20. BigDogBen
    BigDogBen New Member
    03 Big Dog Bulldog
    I'm interested. Just got news that the ehc on my 03 Bulldog is bad.
    Sent from my SM-G960U using Tapatalk
    chubs likes this.
