2004 Mastiff Starter removal question
Discussion in 'Help Wanted' started by raqmup8, Aug 15, 2009.
  1. raqmup8
    raqmup8 New Member
    2004 Big Dog Mastiff
    What about a 2004 Mastiff? Have removed Oil tank then the two starter bolts on a 2004 Mastiff but the starter is still not coming all the way out. Do I need to take the primary case off to get to the starter gear or what?
  2. V
    V Guru
    On the left side drive bikes I do believe you need to take off the primary cover to get the starter off
    LITTLE HELP HERE:lol:
  3. alhall88
    alhall88 UAW
    Petersburg, Michigan
    Yep on the 04 models you have to remove the outer primary cover to get at the 7/16 bolt that removes the gear/jackshaft. After that then remove the rear bolts.
  4. KnotSo
    KnotSo Admin
    Washington
    These tips do the trick?
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Al was spot on back in 2009 . Knotso one more year and it would be a 10 year old thread. Lol
