2004 Tachometer Big Dog Chopper
Discussion in 'Vintage Big Dogs' started by Rick Utley, Oct 11, 2018.
  1. Rick Utley
    Rick Utley Member
    Houston, Tx.
    2004 Big Dog Chopper
    Rick
    Could someone please tell me why neutral light comes on in first gear instead of neutral with brand new tach ring.
  2. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    Kind of sounds like the shift drum is positioned a little off. The neutral switch is activated by a dent in the shift drum. Seems a bit odd though as the trans wouldn't behave correctly if it was off. Check your neutral switch with a continuity tested in neutral and first gear. It may need replacing.
  3. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I just replaced the NSS and new tach but last night when I tested the new tach ring I did not have it put together just plugged in so just maybe it needed to be grounded. Is that possible? Now that I got the new gasket tach ring and speedo back together I will test it tonight as a complete unit...
  4. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I just hooked it all up and neutral light is on in all gears goes out in neutral.
  5. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
  6. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
  7. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    Backwards? That I have never seen. Maybe the wrong neutral switch?
    Rottweiler likes this.
  8. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I’m 110% lost!!!
  9. roadie1389
    Wylie, Texas
    Pull the connector from the sensor. Should go out. Then jumper the pins on the connector. If that works then the indicator light is working and the issue is the sensor. Might be in too far.
  10. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Thank you
  11. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Sounds like you got a N.C. switch instead of a N.O. one. :job::oldswear::oldeek:
    roadie1389 likes this.
  12. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Please explain the difference?
  13. Rottweiler
    Elizabethtown, PA.
    Todd
    N.C. stands for normally closed. The switch allows current to flow through until it is made up.
    N.O. stands for normally open. The switch allows current flow only when it is made up.
  14. Rottweiler
    Elizabethtown, PA.
    Todd
    Did you replace the neutral switch?
  15. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I put the old one back in and it’s working correctly now the tach lights won’t come everything else works fine so I plugged old tach ring in and tach lights work just nothing else
  16. Rottweiler
    Elizabethtown, PA.
    Todd
    Sounds like you have a cold solder joint. On you old tach ring.
    Sent from my Life One X3 using Tapatalk
