2007 Big Dog K9
Discussion in 'Technical Bulletins and Recalls' started by Dog 10, May 16, 2018.
  1. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
    Good morning all:
    I need some help here in Pa.
    I went for a ride yesterday and got only 15 miles.
    Engine shut down, four ways started flashing, and horn honked. Turned the ignition key off and then restarted my bike. This happened twice.
    Got the bike to the shop and now looking for (*)advice on how to resolve this issue.
    (*) Best product to repair and contact of for product.
    Thanks
  2. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
    Test ehc what is the procedure for this ?
    Srodden likes this.
  3. HMAN
    HMAN Just like to ride
    Ks
    Harry
    Pull the ehc and send to Curtis @ Wild Steed Workz. He is a forum vendor. He can test your ehc and then you will know if replacement is required.
    Carl Jett and Srodden like this.
  4. pknowles
    virginia
    paul
  5. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
  6. pknowles
    virginia
    paul
    Curtis staying in business and supplying what we need is supporting a lot of people in the way that is needed. Deca batteries aren't a supporting business but I bet there's a lot of them in the members bikes. Shenko, Metzler, and Avon ???.
    I sure hope dog10 gets the help he's looking for.
  7. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
    Thanks for the advice.
    All sounds like a positive direction to go.
    Big D Florida and pknowles like this.
  8. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    I too support him whenever I can !
    pknowles likes this.
  9. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Sounds like either ehc or a short in the wiring or pcb boards
  10. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
    Good afternoon all:
    Well my K9 is in the shop for a NEW EHC from WILDSTEEDWORXS, NEW Voltage regulator from WILDSTEEDWORXS, and a NEW Battery
    Should be on the road by the June 10, 2018.
    I have seen articles on the E3 spark plugs. Opinion's please.
    (has any borscoped there cylinders after using E3 plugs ?)
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What part of Eastern Pa are ya from and what shop are you using?
  12. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
  13. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    check all your battery connections to make sure they are tight -- loose connections will cause that issue on the road.
  14. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    I use E3's and I started back when I was having real trouble with the bike -- was fouiling out champions in several hundred miles -- put the e3 in and bam -- thousands of miles later the bike still runs. Still have a bit of the issue but that because I havent gotten around to pulling the injectros adn some other things I need to check.
  15. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Used to be (back a few years) a dealer in Wormsleyburg, but their gone now. Don't know where their wrench went.
    Any chance you're heading to Thunder in the Valley in Johnstown PA 21-24 of June -- Great time.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Hershey area
    BlackDogMotorcycles was the place and Randy is across the river from Harrisburg at some shop, don't know the name of it.
  17. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Good to know -- they always took good care of me there. That's where I bought my first Big Dog.
    Mike and Randy always worked with me when I scheduled service since I was 2hrs away! And would ride out early on a Sat for service, even the 10k they spun around the same day for me.
  18. Carl Jett
    Carl Jett New Member
    Illinois
    K-9 2007
    Carl
    I recently bought the replacement EHC from WILD Steed WORX because field mice chewed my wiring up on the EHC (note use moth balls and mouse poison if you store your bike in your work shop) and it works great. My 2007 K-9 runs better now than when I first bought it. ( No more back firing when I let off the throttle)
    dentdude36 and pknowles like this.
  19. pknowles
    virginia
    paul
    Glad to hear you are up and running, now all we need is some decent weather for a change.
  20. Dog 10
    Dog 10 Member
    Eastern Pa.
    Gregory
    Jonesy's Custom Cycle
    363 Sherwood Dr
    Carlisle, PA 17015
    The last I heard Randy was at the shop listed above. Randy is a most excellent wrench and quite talented. The shop ???????????????
    I found Mike at http://www.freebyrdcustommotorcycles.com/ and he is even better. I trust him with my Dog.
    BWG56 likes this.
