2007 bulldog starting problems
Discussion in 'EFI Topics' started by willywill4765, Jan 27, 2018.
  1. willywill4765
    willywill4765 Member
    US
    Okay I have searched on this site for the last 2 hours. Bike Road great all summer, the weather has been decent the last week in the 50s, when to start bike it will kick over but cuts out. Hazard flashing lights come on, check engine light comes on, while trying to start it and puffs of smoke come out of the air cleaner. Using non ethanol gas, batteries charged, plugs are good change them anyway just to double-check. Any help would be greatly appreciated
    Sent from my SM-G900P using Tapatalk
  2. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    If my bike struggles to turn over the hazards will flash and will stop trying to turn over. I turn the key off and it resets, sometimes it cranks and sometimes it does it again. I put a new battery in which helped tremendously but I also found out my compression releases are not staying down but a sec and a half. Bout to replace them in the next few weeks. Idk if that helps you are not
    what? likes this.
  3. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Hazards also flash and horn tries to honk when there is not enough voltage on battery, did you check the voltage while pushing start?
    Srodden likes this.
  4. TapioK
    Tapio
    If I remember correctly the compression releases are originally supposed to stay open about that time. Just enough to get over first pressure... some have rewired them to stay open as long as starter is running. There is a how to somewhere...Sorry I don’t have time to look for it now
  5. Reddickracing
    Louisiana
    Jeff
    Yea my horn would try to make a sound too. Like I said when it put the new Throttle X 500 CCA battery in it helped a lot. I was told on here that the releases are supposed to stay down until it cranks idk. But they are original and gonna replace them any way.
    Big D Florida likes this.
  6. willywill4765
    US
    Thanks I will try that when I get home and check the volts on the battery
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You are correct.:old2:as long as the start button is on.
  8. Reddickracing
    Louisiana
    Jeff
    I have also learned that a battery will show charged and good and still have a dead cell which lowers cca
  9. Griffit
    Griffit New Member
    ohio
    classic chopper
    Bill
    a weak battery will cause those issues, modern electronics need power, you could get by with it if it had points, their not as demanding on an electrical system...
    what?, Srodden and Reddickracing like this.
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I think that was an upgrade if you ditched the EHC. If memory serves me right the original EHC just gave them juice for 1.5 seconds. MoeSpeeds did a how to on wiring them to the solenoid wire.
  11. willywill4765
    US
    Yes the voltage went down when I tried to start it it showed 12.48 and then when I try to start it it drop down to 7 to 8 and 1/2. It was a new battery the beginning of Summer did not have it on a trickle charge, but charged it with a regular battery charger once a month maybe I need to get a trickle charger or Tender
  12. TapioK
    Tapio
    That POS is dead. Get a new one, most likely it still has warranty
    Reddickracing likes this.
  13. Reddickracing
    Louisiana
    Jeff
    Look up "What to do if starter wont turn" by Moespeeds, its prob the thread that Eric is referring to. I looked at it briefly and looks to be very informative.
  14. willywill4765
    US
    Yeah it should be under warranty you think I put it on the charger overnight and then check it will do any good
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    No not 1.5 seconds, the manual stated 1.0 seconds:Don the OEM
    dentdude36 likes this.
  16. Th3InfamousI
    Texas
    Haha I was just going off memory close enough you big bully! Lol
    Big D Florida, BWG56 and dentdude36 like this.
  17. Th3InfamousI
    Texas
    Yep agreed 7-8v ain't gonna work just get a new battery.
  18. Th3InfamousI
    Texas
    That's good to know too! Sounds like all the new stuff has resolved a timing issue that BigDog thought up for no reason.
  19. Hambone
    Hambone New Member
    2007 K-9
    Help! I'm new to this. Tried to start my 07 K-9 (with a new battery) and all I get is the horn screaming at me. What do I check?
  20. HMAN
    HMAN Well-Known Member
    fk it
    Put a charger on the "new" battery overnite and try again. Not all new batteries are fully charged and these Dogs need all the CCA they can get. Jm .02
