2007 bulldog starting problems
Discussion in 'EFI Topics' started by willywill4765, Jan 27, 2018.
  1. pknowles
    virginia
    paul
    And push one of the compression releases in by hand while you are cranking.. It should help keep it spinning.
    Reddickracing likes this.
  2. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    A lot of batteries are in the 285 cca range, I believe Big Dog recommends at least 330 cca correct me if I'm wrong. Even a new battery may not be good enough. When I bought my K9 the owner had just put a new bat in it, was having some issues and looked up the part number and said 285 cca. Same part number with one letter change was the 330 cca. I bought the Throttle X 500 cca
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Mine has been in for over a year so far:old2:
    dentdude36 and Reddickracing like this.
  4. Kenny G
    Kenny G Member
    ramsey, NJ
    2009 Big Dog Wolf, 2003 American Ironhorse Legend
    Ken
    Cleaning my "09 Wolf this afternoon, didn't wash it just polish and rags, running great before went to start it up and wouldn't start without me giving it some gas, then wouldn't idle seem like the idle circuit (if there is one ) is not working. Any ideas? Did not disconnect anything!
  5. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    i went thru 3 different batteries in 1 year, dont buy any auto parts store batteries or batteries plus, batteries, i ended up buying a harley battery and now it has lasted over the 3.5 months that the other batteries would last.
  6. speedball jr.
    speedball jr. Member
    What color is it?
  7. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    I went through 3 batteries in one year too. But after the 3rd battery, that's when I started having more issues. It all started from the EHC. I replaced my EHC with the RIP gen 2 from Big Dog yesterday.
  8. pknowles
    virginia
    paul
    Congratulations:oldthumbsup: Hope it fixed all your problems.
  9. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    Thanks, Once I hooked up the battery after I installed the rip kit, it fired up with no hesitation whats so ever. Everything works perfect now. Only issue was the wiring that comes with the rip kit are a bit to long.
  10. pknowles
    virginia
    paul
    Better than a bit short:oldthumbsup:
    chubs likes this.
  11. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    I so agree. It just sucks that all these big dogs that are out there still have the old EHC and might have issues and not know what the hell is going on.
    pknowles likes this.
  12. pknowles
    virginia
    paul
    Knock on wood, my 07 K9 still has the original ehc with air ride functions. I bought an esc as a spare and still have it on the shelf. I think I paid 575 or so plus another 100 for the air ride controls to function as original. I don't think the RIP kits have air ride function. You have to mount a 3 way toggle switch somewhere and as fragile as the side covers are, I didn't want to drill a 3/8 inch hole in it to mount the switch.
    chubs likes this.
  13. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    Yes, i hear ya, i had an 05 ridgeback for 9 years and it had 20 k plus miles and no issues ever with the EHC.
  14. Murraylw
    Murraylw New Member
    2008 K9,2010 Night Rod
    I have a 2008 K9 with efi, I'm hoping I can get help with a issue that I'm having. Sometimes when riding, the engine shut down and it seems the fuel pump shuts down. When I pull over to restart, the fuel pump doesn't start back up, sometime it does, sometime it may take a couple minutes. So thinking it was the fuel pump,I have it replace with a new one. That didn't help, it still does it, so needless to say it sets in my garage like a paperweight. Could this be a EHC issue? Just want to get some feedback before I purchase a new EHC. I love the bike, but need to get this issue squared away.
    Thanks.,Larry
  15. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    How are you Larry? I believe it is your EHC, mine started with different problems then completely died on me. This is my 5th BD and from what it sounds like, your EHC is going out. I bet if you replaced it the problem will be fixed. If you want to keep your BD I suggest you change out the EHC.
  16. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Had mine do something similar and it was a bad connection on the battery. Check everything is tight and battery is good.
    Does it happen on smooth road or maybe a bump -- you could have a short shutting it down and then waiting for the system to reset.
    When you pull over do you turn key off or just try the run/off switch and start button?
    What area of the country are you in -- Might be one of us is near by and can help you out.
    chubs, HMAN and pknowles like this.
  17. willywill4765
    willywill4765 Member
    US
    Think I'm having the same problem I got plenty of volts on the battery but it doesn't want to crank over cranks once and then stops. Was pretty easy to buy and install the r R.I.P kit..?
    Sent from my SM-G900P using Tapatalk
  18. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    Hey Willy, Actually it was easy to install. I bought the one from Big Dog. It takes about an hour to install. I suggest getting the one from big dog, customer service is always there and they normally have them in stock, other places don't have them in stock.
  19. willywill4765
    US
    Appreciate the info how much was the new rip kit
  20. philquint
    philquint Member
    albuquerque
    2008 ridgeback
    phil
    No problem, it was 700. Well worth it. Instructions to install are on point as well.
