2007 K9 Over fuelling (flooding)
Discussion in 'Technical' started by TYHG, May 31, 2016.
  1. TYHG
    TYHG New Member
    United Kingdom
    2007 K9
    Tony
    I recently purchased a 2007 Bigdog K9 (117 S&S engine, super G carb) with supertrapp exhausts & a S&S Tuned Induction Air Cleaner Kit installed.
    I can start the bike but within a few minutes it over fuels to the extent that fuel leaks (drips) from the lower air filter, the bike runs very rich, plugs are soot black and small amounts of black smoke come from the exhausts, the bike will not idle, runs lumpy and will only pick up if i open the throttle to around 2k RMP and above.
    Prior to my purchase the bike had been stored for a few years, i have flushed the fuel system through, removed the carb bowl (found some very small debris), removed & cleaned the intermediate jet, main jet & main jet air bleed, put the carb back together and set the idle speed screw, idle mixture screw & accelerator pump adjustment screw to stock setting, i tried to tune the carb in but still had the fuel leaking from the intake, i didn’t want to carry on for risk of fire.
    Any suggestions on how to move forward would be very much appreciated.
    Cheers
    Tony
    chubs and Bdm4ever like this.
  2. HMAN
    HMAN Just like to ride
    Ks
    Harry
    Welcome from Kansas. It sounds like your float is sticking and causing the overflow. Or, you have some dried up gaskets that need replacing?
    chubs, BadDawg Bill and dentdude36 like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    chubs, dentdude36 and francoblay1 like this.
  4. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    :agree:
    I beat me to it wanker! :oldlaugh:
    :old2:
    Intros: HERE
    chubs, dentdude36 and BWG56 like this.
  5. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    Definitely need a carb rebuild kit.
  6. Bdm4ever
    Bdm4ever Well-Known Member
    Something Like K9
    Tony
  7. Bdm4ever
    Something Like K9
    Tony
    :agree:
    francoblay1, chubs and dentdude36 like this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Sounds like I drunked to much already:oldlaugh: Oh, and the carb prolly needs a rebuild
    #8 BWG56, May 31, 2016
  9. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Welcome from Washington State, hope you enjoy the site... :cheers: Agreed, possible stuck float...
  10. francoblay1
    K9 (2006)
    Franco
    :oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh: :old2: :cheers:
    Bdm4ever, chubs, BWG56 and 2 others like this.
  11. mjsk9
    mjsk9 Active Member
    Carmel, IN
    2006 K9, 2008 BBC Pro Street Sled
    Mark
    Not going to resolve the fuel spilling but if the plugs are "soot black" and fouled, they need to be replaced since that will cause erratic running of the engine at lower rpms
    chubs likes this.
  12. dentdude36
    dentdude36 Banned
    Upstate NY (suburbs of Buffalo)
    2007 K9
    kevin
    Did you get this figured out?
    francoblay1 likes this.
