2018 BDB Big Dogs Unleashed Booking info
Discussion in 'Big Dog Biker 10 yr Anniversary Gathering' started by Mr. Wright, Dec 28, 2017.
  1. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Just a little note: If your riding in, make sure you fill your bike up before you get there. If your coming on 400 fro the East, Fredonia is the last gas station. And if your coming from the west, somewhere around where 99 intersects 400, there is a station.
    If you pulling there, bring an extra 5 gal with you, because someone will forget.
    #101 Mr. Wright, May 4, 2018
    chubs and BigDogRick like this.
  2. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    Haven't decided yet if pulling or riding, but thanks for the heads up, and I'll bring extra if pulling.
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
  4. liferider
    liferider Guru
    Louisiana
    Jonathan
    It looks like Colleen is coming so I will bring 4-5 gal fuel jugs with 93 octane for those who go oops
  5. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    So I'm still chasing grimlens.. was hoping to ride the whole way, but we shall see what happens.. kind of believed o got screwed when I did all that work and either my heads or jugs aren't true.. so we shall see and now r cutting it close. Lol
    chubs likes this.
  6. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Just got a list of door prizes, from a very generous donor. Door prizes will be given out Friday night, so make sure your there. And yes, we remembered the ladies this year. Bike show also on Friday, so get there early.
    chubs likes this.
  7. HMAN
    HMAN Just like to ride
    Ks
    Harry
    If anyone gets hung up in Kansas, holler. I have a trailer. In Wichita. 31631277six oh.
    Mr. Wright, chubs and pknowles like this.
  8. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Were just a month away
    pknowles and chubs like this.
  9. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Getting closer.
    A question was asked about bringing the kids. Yes by all means, they are welcome. They have a pool and fishing. But there isn't any tv's in the rooms.
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I forgot there wasn't TVs! haha. But not like we spend anytime other than to sleep in the room
  11. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    No tv, but there is a gun rack. How cool is that.
    chubs likes this.
  12. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    What kind of guns could we bring should we decide to and what are the shooting rules. Is there a long range like 600 to 1000 yards? Are 50 cal rifles allowed?
    Just asking and I realize I could just call them.
    Huw
  13. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    If you want to shoot the big guns, you can stop by my place. Flint Oaks doesn't actually have a gun "range", just a place to waste ammo.
  14. Nukeranger
    Luling, Louisiana
    Huw
    Thank you Shannon,
    I'll leave the guns at home then.
    Huw
    pknowles likes this.
  15. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    I have an idea for a game - See how many bikes Kevin can polish in an hour. :)
    chubs likes this.
  16. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    As your heading into Flint Oaks, the first building on the right as you pull into the drive, is the registration office.
    chubs likes this.
  17. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    Why are you guys using such high octane gas in a 9.6:1 compression engine. Octane should be matched to compression. 93 octane gas is formulated for 11:1 or even higher compression. 89 octane gas will likely burn more completely in our engines. Why waste money on gas designed not to pre-ignite with high compression Ducatis, Ferarri's, Lambos etc... Premium does not mean more power or cleaner gas. The BTU of 87 octane gas is the same as 91. Ethanol lowers the BTU's but increases the octane.
  18. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    You are correct, to a point. The book says 91 and above only, and up to 10% Ethanol is ok. Some of us are running a bit more compression than stock. Plus I don't mind spending a few extra cents per gal, for my lady.
  19. Nukeranger
    Luling, Louisiana
    Huw
    I always select the premium gas for my prized possessions. If the book says 91, then I'm selection it or higher. Same is true of my corvette.
    Sure, running down the freeway at a constant speed doesn't really need high octane. But, who does that. It's boring.
    cdogg556 and Mr. Wright like this.
  20. SEAL-rider
    Del Mar, CA
    Spencer
    Cut right out of the 2005 manual: FUEL SYSTEM: Use only unleaded gasoline. Ethanol blended gasoline is approved as long as it has 87 octane minimum. Methanol or methanol blended fuel is NOT approved for use in your Big Dog Motorcycle.
    Does the later model manual change this to 91. When did BD raise the compression above 9.6:1
    Yes, if you have bumped your compression above 10:1 then 91 Octane would be appropriate, but not 93+. Premium is a misnomer. It should really be labeled slow burn/anti-knock and 87 octane labeled fast burn. There is an optimum octane for a given compression and that is what should be used. High octane racing fuels can actually lower HP and torque when not compressed sufficiently, especially as the engine heats up. This is based on numerous published tests. Science seems to indicate that engines will perform best with the lowest octane that will prevent pinging.
