569 cam specs
Discussion in 'Motor' started by mleach72, Dec 6, 2018.
  1. mleach72
    mleach72 New Member
    Pennsylvania
    2005 big dog pitbull 2005 softail deluxe
    Matt
    I know there have questions in the past about the stock 569 cam specs. It took a lot of digging, but I found them a few years ago. Here they are, if anyone is interested. As you can see, it is definitely a shitty epa cam. The -2 intake opening and 6 degrees of overlap is not what you would call a "performance" cam.
    #1 mleach72, Dec 6, 2018
    john sachs likes this.
  2. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    So what I found last year when doing the rebuild on my engine and all that, the 117 from S&S came with a 600 of u got a crate engine, our engines were EPA rates and significantly downtuned. I know a lot of the guys are running a 585 I believe, but never heard of this one and couldn’t tell you much about it
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    This 569 Is still in your bike....haha.
    So you do know about it
    bdm7250 and francoblay1 like this.
  4. mleach72
    mleach72 New Member
    Pennsylvania
    Matt
    The 569 was the stock cam in '05 and '06 and maybe some of '07. If you have a 117 with TP rocker boxes, you have a 569 cam. If you have the s&s boxes, the stock cam is the 546.
    bigkelk9 and francoblay1 like this.
  5. Ernie12
    Ernie12 Active Member
    Ohio
    02 BD Pro Sport
    Ernie
    I'm thinking of doing a cam upgrade on my 2002 S&S 107. What do you guys recommend ? Only 3570 miles on the motor.
  6. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    I called BDM and was told that most 107s came with the 600 or the 520. I called S&S with my SN and they told me my piece engine had a 520 when shipped from them. If I ever get my butt in gear I am going 585. I am pretty sure my bike does not have the 600. Just have not felt like taking the cam cover off.
    PacoPetty and fiftyonefifty5150 like this.
  7. bigkelk9
    07 big dog k9
    Kel
    No fool, I put the other cam in when I did all the engine work on my bike, got it from donna and derick
    pknowles likes this.
  8. Th3InfamousI
    Texas
    Well it's the one you took out then. You had the 569 when you did the lifters at my house
    PacoPetty likes this.
  9. bigkelk9
    07 big dog k9
    Kel
    No fool, I had the 546!! Pay attention!! Geez!!
    francoblay1 likes this.
  10. bigkelk9
    07 big dog k9
    Kel
    Killin me smalls!! I got all my information from S&S before I did everything to make sure it was exactly as it was supposed to be for the engines sake, not performance. The way these things are epa rated and dummies down actually hurts them
  11. DynoDave
    DynoDave Active Member
    Tucson, AZ
    2002 Big Dog Mastiff
    I have a 600 cam in my 2002 and it runs like a beast!
    Butch Cassidy and john sachs like this.
  12. mleach72
    mleach72 New Member
    Pennsylvania
    Matt
    I'm not sure what the compression ratio is on the BD 107's. I'm sure someone here knows. If it's in the mid to high 9's, the 585 is really great. It made a big difference in my 117. If it's over 10:1 cr, the 600 is probably a better choice.
  13. roadie1389
    Wylie, Texas
    Was it stock or did you change it?
    Sent from my SM-G892U using Tapatalk
  14. Butch Cassidy
    Butch Cassidy Active Member
    Fate Texas
    2000 Bulldog
    BUTCH
    I have a '99 model 107 with a 600 cam. 9.7 CR. S&S told me I could run 87 in it, just don't hammer it. But 89 would be just fine. Definitely a motor for an experienced rider of high hp bikes. Plus, I had Bob Maltz of xXx carb do a 'tune up' ....
  15. DynoDave
    Tucson, AZ
    Well...both! After 21,000 miles I dropped a lifter and it trashed the camshaft. Replaced the stock 600 cam with another one. Also have a XXX Mini Taz carb. Great combination!
    Butch Cassidy likes this.
  16. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I still have 546 but it’s like never having cruise control. If you never had it, you can’t feel like you have to have it.
    chubs likes this.
  17. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    :willynilly: JUST DO IT!!!!! Go up to the 585 and you will be smiling even more!!! :chopper:
  18. Th3InfamousI
    Texas
    With my riding style I never really noticed a difference with a 585 or the ignition module. I guess I ride like a pussy....
    Biggest notice for me was a loss of 3-4mpg
    francoblay1 and pknowles like this.
  19. mleach72
    mleach72 New Member
    Pennsylvania
    Matt
    The 585 was a big difference for me. Low end torque felt stronger, and the bike now pulls hard all the way to redline. With the stock 569, it would start falling off around 5000 rpms. I also lost a few miles per gallon with the cam swap, but I went to a smaller pilot jet and smaller pump nozzle on the mikuni, and mileage is pretry close to where it was before the swap. I didn't notice a big difference in performance with the TH ignition, but it did make the motor smoother. Hard to explain, but you could feel that immediately.
  20. francoblay1
    K9 (2006)
    Franco
    I really did notice the Cam, the TH Module is hard to say... I didnt play much with it, I just left it at Setting #3.
    :chopper:
    X2
