Another rookie question
Discussion in 'General' started by John Cingel, Oct 5, 2017.
  1. John Cingel
    John Cingel Member
    Parma Ohio
    2008 Mastiff 2011 Stratoliner deluxe
    John
    Finally replaced my clutch cable the other day that I broke after replacing my throw out bearing and clutch hub nut. And when I took the bike for a ride the noise I was hoping to eliminate was still there. I also noticed my clutch pushrod looked a little scored. So I ordered one from baker. While talking to the rep I described the noise to him and he seemed to think it was the clutch hub bearing. There is the question. If I order the machined clutch basket from shovelheadkicker with the bearing in it is that the bearing I need to replace? Also while pulling the primary apart again is there anything else I should be replacing like seals, o rings, other bearings. Thanks
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Yes that's what he's talking about, I didn't know Derek had them.
    Baker drive train,
    *Assembly
    Carrier Assembly
    1
    3054A-DSSC
    395.00
    #2 BWG56, Oct 5, 2017
    dentdude36 likes this.
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Yes Derek bought a lot of them, I think. There was a lot of like 20+ on eBay one time. And you don't have to buy the inner hub.
    With that said I don't foresee that bearing going bad however. I doubt that is the cause of noise but you can take it apart to see. That bearing is HUGE should outlast any amount of miles most will ever put on a BigDog. It's about the same size bearing I have on my 4x4 1500 truck on the front wheel hub.
    I think the splines on the inner hub would fail before that bearing does. Or if you have the stock carrier that would certainly break before.
    you can check the teeth on the inner bearing hub, baker has an updated one.
    #3 Th3InfamousI, Oct 6, 2017
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I beg to differ young grasshopper, my inner hub did go bad from the clutch hub nut coming loose, when I spin it in my hand I can feel the click or indent the bearing had made in the hub. At that time it was not the hardened hub.
  5. Th3InfamousI
    Texas
    I did say the inner hub would go bad BEFORE the bearing...go reread my post.
    Per the OP baker rep said clutch hub Bearing....im saying I doubt it, inner hub fails first.
    If OP just replaces the bearing I don't think he fixes his problem. Was where I was going. Which is what Baker seems to have been implying.
    The one from Derrick and Donna doesn't come with the inner hub either.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The bearing will take out the inner hub, yes, so changing the inner bearing is not going to fix the inner hub
  7. Th3InfamousI
    Texas
    Same page! High Five!
    TapioK, cdogg556 and BWG56 like this.
  8. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    [​IMG][​IMG][​IMG][​IMG]
    BWG56 likes this.
  9. John Cingel
    John Cingel Member
    Parma Ohio
    John
    So if I order this From Baker I should be covered?
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Yep, that's it:old2:
  11. Th3InfamousI
    Texas
    Isn't that the old one? They got an updated one that isn't cast
    Forsaken likes this.
  12. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Expedited shipping if you want it sooner than later they seem to take a long time to ship from my experiences
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I think it depends on their inventory, but he will prolly get the billet one would be my guess because the cast have been used up, he can ask.
  14. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Everything I've ordered from them was shipped out the same day and I had it in 2-3 days.
  15. John Cingel
    John Cingel Member
    Parma Ohio
    John
    I got the clutch basket with the inner hub & bearing ordered along with a new clutch hub nut & washer. Question is are there other things I should be replacing while I've got the primary apart?
  16. John Cingel
    John Cingel Member
    Parma Ohio
    John
    I'm trying to get it done by this weekend and wanted to have all parts before I start.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    A new inspection cover gasket, 1 quart of primary oil, check your chain tension 5/8-7/8"play and look to see if you have the hard coated pressure plate, its a yellowish dark green color, not shinny aluminum. When the clutch disc's and plates come out, stack them so they go back in the same way they came out.:whoop:
  18. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    You SUCK! Don't forget it
