God – don’t let me get started on this problem! But it was able to fix it.
First, to be technically correct the condition is an afterfire, not backfire. Afterfire is in the pipes, backfire is in the carb. Had to be either fuel or ignition.
Did everything to the carb, including aux vent removal. Some said float because the carb is on the right and the bike leans left on the kickstand, that after you ride and put it on the stand leaning left, fuel drips down the hot intake and pipes and Ka-Boom. Well that did not work either.
Next ignition. For BDM that’s controlled by ECH – but that was changed 2 or 3 times and always had the problem.
Mine was really bad and I have it on video – In the dark you could see a flame shoot out of the pope at the same.
Hate to say it but the remedy ain’t cheap but guarantee to work.
I pulled all my wiring and direct wired the whole bike. I’m one if the first to dump the ECH. I also changed to a Mukuni carb. That was about 6 months ago and the bike has NEVER done it again – Never.
Was it the carb or elimination of the EHC? Don’t know but it worked.
An afterthought that came to me is this – When I did the conversion I went to a Crane ignition which requires a cam sensory. Dogs use a crank sensor instead. I blocked the crank sensor and had to get a new cam cover case that has a sensor for the cam, instead of the crank – so that could be part of the problem. Maybe carb is OK, ECH is OK but it’s getting a false signal from the crank sensor..
My direct wire was elaborate changing everything BDM, speedo, controls, etc over to standard HD stuff.
You may check out bdmridgeback - he has a conversion kit that allows you to dump the ECH and still keep the stock controls, speedo, etc. However, I think his set up still uses the original crank senssor.
