Baker Primary Belt Drive
Discussion in 'General' started by edspesh, Oct 6, 2018.
  1. edspesh
    edspesh Member
    Layton, Utah
    2005 Pitbull
    Ed
    I've fallen victim to my own preaching! Have a little weeping out of the shaft oil sprocket seal and spacer after installing this belt drive. Hmmm....shouldn't do that but oh well. Also, this setup sounds like a turbo. I'm told its because of the deep grooves in the belt, front and rear sprocket. Any thoughts?
    Drive Sprocket Spacer HD#24002-70 BDM##31-4011
    Sprocket Shaft Oil Seal HD#12026B BDM#31-4010
    Kind regards, Ed.
    PacoPetty likes this.
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Even after cleaning your stator really good with brake cleaner, as soon as it heats up, more oil will come out. As long as you turned the crank seal around backwards, you should be good. Just give it a few runs to dry up the excess oil.
  3. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    That looks great!
  4. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Check THIS out. :oldthumbsup:
    :chopper:
  5. pknowles
    virginia
    paul
    Kind regards, Ed.
    Jjoyce said:
    First off is your crank seal leaking? You should have put a new one in reversed from the original ( no brainer since it’s already apart) , did you completely clean the stator? Yes the belt drive will whine and sound like a blower not necessarily a turbo as turbo chargers are not driven in the same matter with a belt and pulley
    :chopper:
    #4 francoblay1, Oct 6, 2018
    Report
    Damn Franco, I guess you have scared JJOYCE off as it seems he has deleted most of his posts:) Thanks for sharing
    francoblay1 and HMAN like this.
  6. KnotSo
    KnotSo Admin
    Washington
    Jjoyce is an alias of BWG56
    chubs and SKOGDOG like this.
