Battery Tender
Discussion in 'General' started by TexasDawg, Dec 23, 2018.
  1. TexasDawg
    TexasDawg New Member
    Texas
  2. 41bigdawg
    41bigdawg Let the Big Dawg eat !
    Portland, Tennessee
    2007 Big Dog K9, 2012 Heritage Softail, 2018 Honda 250 Dirt bike
    Robert
    It sure is, cant go wrong with a Real Battery Tender. That one is 12Volts, the higher the amperage the shorter the charge time. I have one of those and it works great, also have 2 of the double bank systems at 12V 1.25amps they will bring a battery back from the dead in an hour or 2. :chopper:
    #2 41bigdawg, Dec 23, 2018
  3. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
  4. pknowles
    virginia
    paul
    Thanks for the link:oldthumbsup:
  5. Letbigdogintocanada
    Letbigdogintocanada Active Member
    32118/P1H0A7
    04 bulldog 09 streetglide cvo
    JR
    I have been using those for 6 years,not even 1 glitch,good product
  6. Minuteman
    Minuteman Active Member
    Orange, Mass
    06 K9, 02 Ultra, 77 FLH, 57 Sportster
    Ted
    They work great
  7. Ernie12
    Ernie12 Active Member
    Ohio
    02 BD Pro Sport
    Ernie
  8. 41bigdawg
    Portland, Tennessee
    Robert
  9. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    I bought a couple of chargers from Mad Dog years ago. They do the same thing and desulfates the cells. That's what it says anyway.
  10. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
  11. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
  12. Sven
    Sven Well-Known Member
    building one
    Formula goes something like this:
    Numbers for volts and letters for lead post position and/or poles swapping w/amp rating. So if we buy a 12N12a battery, move the decimal point to the right of 12 and then this represents 1.2a. This says you need at least a 1.2 amp rated charger. To charge the battery, the remaining formula says to charge the battery for literally 12 hours with a 1.2a charger.
    If say you buy a 12N14a battery, you won't fully charge a 1.4a battery with a 1.2a charger. So you run formula to buy the charger needed for said battery. And then you use a 1.4a or higher [1.5a rated say] charger and charge it for 14 hours with a 1.4a rated charger.
    Now say you have an 8 or 10a car charger. The problem with this is the chance of overheating the battery if charged too long. So you feel the body case for heat. Problem being: the bubble size. Meaning, the difference between a boiled water bubble as opposed to champagne bubbles. The large bubbles will blow out, buckle the plates with that kind of heat [rating].
    Make sense?
  13. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    pknowles likes this.
  14. kickstart
    TN
    Pat
  15. Reddickracing
    Louisiana
    Jeff
  16. HiTech
    HiTech New Member
    41.636° N -80.151° E
    Mastiff
    Desulphating chargers are good but you shouldn't be using that feature too often. The best method is to charge the battery to full, discharge it to a low level, then desulphate as it recharges. Some of the desulphating chargers don't incorporate those steps in an automatic sequence thereby risking a lowered battery life.
  17. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    I have had no issues for over ten years! I have two plus a double unit in the barn.
  18. HiTech
    HiTech New Member
    Mastiff
    Are your chargers TRUE desulphator type operating in the method I mentioned or are they labeled as high freq. charging/desulphator? There's a difference. The latter type minimally desulphate(perhaps better than nothing, I guess!). Years ago Vector made a true desulphator that took no less than 24hrs & longer to properly desulphate.
  19. JB105
    JB105 Member
    Wellsville Ny
    2006 K9
    Jeff
    Let’s not get overheated here and keep this thread going in the right direction, here’s what I use on all my batteries whether is a an atv, pwc, riding mower or my motorcycle. Works great and desulfates the battery plates for longer life span
    BatteryMINDer Model 2012-AGM: 12Volt-2 Amp Battery Charger Maintainer/Desulfator for Odyssey, Optima and AGM Lead-Acid Batteries - Designed for Cars, Trucks, Motorcycles, ATV, Boat, RV, etc. https://www.amazon.com/dp/B005EKY20K/ref=cm_sw_r_cp_api_i_wrkxCb8WZPN9G
    PacoPetty and Reddickracing like this.
  20. awg
    Ohio
    And there you go!
