Belt slipping
Discussion in 'Vintage Big Dogs' started by Rick Utley, Jun 5, 2017.
  1. Rick Utley
    Rick Utley Member
    Houston, Tx.
    2004 Big Dog Chopper
    Rick
    Good evening, I have an 04 Big Dog Chopper 117cu in. When I really twist the throttle hard especially two up my belt slips on my rear sprocket has anyone else had this issue? Belt and pulley have some wear but not that bad. Belt is tightened to specs maybe a little more. Any suggestions? Thanks...
    chubs likes this.
  2. pknowles
    virginia
    paul
    You need to really look at the wear on both parts. It shouldn't be slipping. That wears the hell out of the parts. Can you post a picture
    chubs, BWG56 and bigkelk9 like this.
  3. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I certainly can and will when I get home and will greatly appreciate any help on this matter I can get really frustrated...
    chubs and bigkelk9 like this.
  4. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Something tells me ur pulley on one side or the other is wore (gear or pulley).. ur belt will be next.. I'd take it off and do a close inspection on them teeth
    Srodden, chubs and BadDawg Bill like this.
  5. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Had actual mechanic look at it he said it had some wear but should not be slipping. Maybe I need
    To tighten up a little more...
    chubs likes this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    When you say spec, how much deflection is it now?
    chubs likes this.
  7. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Well when you twist the belt with some effort you can't quite twist it a 1/4 turn. I no know it all and trying to pretend to be but isn't it true the more weight the looser the belt gets and nine outta ten times I'm 2up approx 350 Lbs.
    chubs likes this.
  8. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    You sure it's the belt and not the clutch?
    chubs likes this.
  9. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Mech just pulled clutch out and side it was ok throw out bearing was shot so replaced it
    chubs likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I can only get about 1/8 twist on my 07' however this is what the 07' manual states
    chubs and bdm7250 like this.
  11. pknowles
    virginia
    paul
    They make a tension gauge to measure the deflection. I bought one a while back and it takes a bit getting used to it.
    chubs likes this.
  12. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    So tell me what is right at the point of being to tight without a gauge by twisting the belt. 1/8 ???
    chubs likes this.
  13. shansel88
    shansel88 Member
    Jacksonville FL
    2004 Chopper
    Sam
    Ive gone through this very thing. Tighten the belt and be done wit it. I replace front pulley and rear and belt. In the end - nothing worked - under heavy acceleration the belt slipped. So I found the choices to be: lay off the throttle, tighten the hell out of the belt, or find a balance between the two.
    chubs likes this.
  14. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Shansel88 that's what I am asking when you tightened the hell outta the belt did it stop slipping??!
    chubs likes this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's what I would think, and it should be on the ground, not up on a jack cause the tension is different with the weight of the bike on the back tire. Assuming the pulley teeth are in good shape, some one on here had shown one not to long ago that the pulley teeth were sharp from wear
    Maybe you need a new belt if that's the original
    chubs likes this.
  16. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Thank you
    chubs and BWG56 like this.
  17. pknowles
    virginia
    paul
    I posted a picture of my wife's Heritage rear pulley that were worn in half and all the teeth on the belt were cut loose on the load side.
  18. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Mines not nowhere near that bad but I am lost
    chubs likes this.
  19. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    Sutton
    Didn't answer my specific question: are you SURE the belt is slipping and NOT the clutch?
    Lots of guys have had issues with the clutch slipping and 99% of the time it's because someone put synthetic fluid in the primary because everyone thinks if it's synthetic, it has to be better. That WILL make a clutch slip in these bikes. Plain old Harley primary oil is all you should use. NON synthetic.
  20. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    No sir I am not 100% sure I do how ever know it has plain ole Harley primary oil in it I cannot swear it has never had synthetic in it.
    chubs likes this.
