big dog bulldog 2005
Discussion in 'Technical' started by Aussie Craig, Apr 21, 2017.
  1. Aussie Craig
    Aussie Craig New Member
    Queensland Australia
    bulldog
    Craig
    Hi there I purchased a 2005 bulldog and shipped it over to Australia. Ive only had it a couple weeks and the bike shut down. the horn went off. so i removed the earth from the battery whilst on the side of the road and then started to check the wiring so i placed the earth wire on with the ignition off and the speedo powered up and horn sounded so i removed the horn wire so i had piece and quiet. but still can't figure out why theres power to my speedo with the ignition off. it also ruined my brand new battery ist now useless. Ive tried to do some diagnostics with a new battery power to the EHC but none on the other side. Does it sound like its the EHC or possibly something else
    chubs likes this.
  2. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Ruined the battery? Overcharging? Could well be EHC, but something caused it, faulty Voltage Regulator?
    chubs and bdm7250 like this.
  3. Aussie Craig
    bulldog
    Craig
    I also took it into my local Harley shop as theres not to many bike shops around here they told me they have tested the voltage regulator and it seems ok. whats your thoughts
    chubs likes this.
  4. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Sounds to me like a short, unplug the EHC and try some dielectric grease and only plug one connector in at a time to see which if anything happens with each, that will narrow it down on which harness if there is a short.
    The other thing would be to remove the tank and unplug the speedo connector and see if that's the short
    TapioK, chubs and bdm7250 like this.
  5. Aussie Craig
    bulldog
    Craig
    ok awesome ill try that.
    I was going to purchase a ehc as it seems its a matter of when it fails not if. But Im still unsure of which one to buy. The DOC or axels which i believe is for sale at bigdog is back. any thoughts and recommendations. as I'm certainly no electrical guru
    chubs likes this.
  6. Aussie Craig
    bulldog
    Craig
    I did pull every connector apart and spray electroclean on them prior to taking it to the harley shop but ill definitely try what you suggested
    chubs likes this.
  7. BWG56
    BWG56 Guru
    Big Dog
    Ker
    The new Big Dog only has the RIP kits, I personally along with many others have DOC's ESC and have been running trouble free, however Axel's is the simplest, just literally 2 connections, remove the old EHC and plug the new one in its place, but its very new, however working well.
  8. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :agree: If your wire harness is not in the best condition, DOC's ESC is most definitely the way to go..over 7k trouble-free miles for me..:old2:
    chubs, DrRx and BWG56 like this.
  9. TapioK
    Tapio
    I'm still stuck with the ruined battery part...
    chubs likes this.
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I'm still stuck on what "removing earth from the battery" means. Moving earth is a tall task.
    chubs likes this.
  11. Big D Florida
    Troop Supporter Supporting Member
    US... Ground
    Europe... Earth
    In DC terminology it is actually... Return
    chubs and pknowles like this.
  12. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2008 HD Fatboy
    Rick
    It's best to use a D-6 Dozer when removing that earth. :cool:
