Big Dog "EHC R.I.P" Signal Cancel function
Discussion in 'Technical' started by RickG, Jun 7, 2018.
  1. RickG
    RickG New Member
    2005 Mastiff
    Can anyone tell me how the signal cancel function works on the R.I.P. EHC? Does it cancel based on the speed of the motorcycle? For example above 20MPH it will shut off. Is it a timer function that stops after 20 blinks? Or does it cancel after traveling X number of feet? Lastly, does the blinker stay on with brakes applied?
    1. Cancel based on speed?
    2. Cancel after x number of blinks?
    3. Cancel after x number of feet traveled?
    4. Stay on with brakes applied?
    I tried emailing and calling BigDog, but no response.
  2. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    I believe it's 10 flashes and I would say yes it still blinks with brakes on. Otherwise you would be getting pulled over if your on a slight hill and turning and a cop was behind you.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Its counting teeth from the speed sensor
  4. MossBerg590
    Arizona
    Tyler
    Yeah definitely not 10 flashes..lol. Just checked. Not sure where I got that from.
  5. Th3InfamousI
    Th3InfamousI Administrator
    Texas
    04 Ridgeback & 07 K9
    Speed sensor is a magnet it has no teeth! The gears have teeth though In the transmission that the speed sensor counts! Haha you asked for it
    chubs, francoblay1 and pknowles like this.
  6. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Get ready for the right answer:):rolleyes:
  7. Th3InfamousI
    Texas
    Im pretty sure ours is a Hall Effect Sensor
    Hall Effect Gear Tooth sensors provide digital pulses as gear teeth pass by that when paired with a counter can be used to track a rotational or linear position.
    chubs likes this.
  8. roadie1389
    roadie1389 Well-Known Member
    TX
    I have a rip -
    Yes still flashes with Brakes applied.
    Flashes when stopped does not cancel (IE stopped at stop light).
    Hazards also work
    I have not figured out the "how long" It just turns off. I know that I will hit the signal then have to hit it again because I hit it too soon. I think it is a timer. You can send an email or call ThunderHeart. They make the micro controller. They can tell you.
    chubs likes this.
  9. dentdude36
    dentdude36 Banned
    Upstate NY (suburbs of Buffalo)
    2007 K9
    kevin
    It's controlled by the ehc on Axels you can program the self cancellation to your liking not sure on rip
  10. RickG
    RickG New Member
    2005 Mastiff
    I wanted to close this out. I called Thunder Heart and they said R.I.P. module is manufactured by them and is the ES4260 MHC, The big difference is the wiring in the R.I.P. kit to fit our dogs. He told me they cancel the signals after 1/10 of a mile or 520 feet.
  11. SEAL-rider
    SEAL-rider Active Member
    Lifetime Supporting Member
    Del Mar, CA
    I just do it manually. Too much risk that someone making a left or right hand turn after you come out of your turn will pull out and want to meet through their drivers side window.
  12. Axel
    Axel Member
    Germany
    2 x Shovelhead (old iron) and 1 Ridgeback 05 :-)
    Axel
    I have in my EHC´s the possibility to set the number of flashes permanent, 20 times or 40 times. For my own opinion are 40 flashes fine until canceling but this is my personal taste.
    All the best and have a nice weekend!
    Axel
    chubs and pknowles like this.
