Bike throwing up!
Discussion in 'Technical' started by TapioK, Feb 1, 2018.
  1. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Shit!
    Trip didn’t start too well!
    Halfway to Miami bike figured it is good idea to breath all the oil out rather than circulate it... what the fuck causes that
    [​IMG][​IMG]
    Need to call a tow truck to take bike back home and borrow friends bike... that sucks
    Tomtang likes this.
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Clean it up and see where it's coming from. May be as simple as a push rod tube leaking.
    HMAN likes this.
  3. HMAN
    HMAN Just like to ride
    Ks
    Harry
    Is the oil cap tight?
  4. TapioK
    Tapio
    Looks like it pukes to breather tube
  5. TapioK
    Tapio
    Huge white cloud...
  6. TapioK
    Tapio
    Shit on return oil line?
  7. TapioK
    Tapio
    I did call a tow truck, no time to look into it now, friends are flying int Miami tonight... I just drop the bike to shop near me and let them look into it while I ride with friends Ultra. Maybe I can switch bikes in the middle of our road trip...
  8. TapioK
    Tapio
    Must say this sucks a bit.
    Tomtang likes this.
  9. TapioK
    Tapio
    Paul, Good point, but I have been using it somewhat every other day and it did puke after 60 miles on highway...
  10. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    Its from sitting. My 03 did that after sitting. Oil can pool in the crank case. You should be fine. Check the valve in the breather line between the jugs. That vavle can get get gummed up. You can take it out and use some break clean to clean it out.
    Tomtang and pknowles like this.
  11. TapioK
    Tapio
    That was my first thought, that puking should happen right when you start the engine, not after 60 miles ? Bike actually did kind of same thing but lesser once about a year ago after 300 miles ride. Then I thought it was just breathing after heavy ride (90-100 mph) on highway
  12. TapioK
    Tapio
    Anyways, I’m at the beginning of 1000+ miles trip... don’t want to ride thinking whats causing this all the trip... or damage the engine...
    pknowles likes this.
  13. jarmet
    jarmet Member
    Finland
    Pitbull 2002
    Jamo
    Really shit thing :mad: I feel sorry for you.
    Hopefully you will get the problem solved soon :old2:
    Good thing is that as a finnish guy we are used to all kinds of shit storms and we always keep on pushing forward with sisu:cheers:
    BobbyD, pknowles and TapioK like this.
  14. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Look like its puking out of the breather based on how high the oil is getting up to the seat and struts!
    I think JR is right you could try running to a auto parts store and getting a new vacuum breather on that rear head. Bring the old one into the auto parts store tell the guy behind the counter to match it up and they cost about $2-3.
    Remember the front cylinder SUCKS the Rear BLOWS on the 117. So if you take that vacuum connector out you should be able to blow with your lips but not suck. If you cant feel the air coming out when you blow you know it's bad.
    #14 Th3InfamousI, Feb 1, 2018
    TapioK and BigDogRick like this.
  15. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2004 HD Fatboy, 2008 Jeep Rubicon, 1972 VW Bus
    Rick
    That looks like what the Evo 107s do whenever the oil reservoir is over-filled. It essentially discharges the excess oil through the breather tube at the air filter. I have not heard of it happening with the 117s.
    TapioK likes this.
  16. BigDogRick
    Phoenix, AZ
    Rick
    This sounds really plausible.
    TapioK likes this.
  17. JR03CHOPPER
    Orlando, FL
    JR
    Not necessarily. Pressure must build in crank case to push it out...and if the vavle is stuck....it can open inadvertantly and allow the flow out.
  18. TapioK
    Tapio
    Could be, the engine is running just fine... I don’t expect anything disastrous, just don’t have time... have to be in Miami tonight
    JR03CHOPPER likes this.
  19. Th3InfamousI
    Texas
    Yep I think it's one of two things either check ball is stuck open in the oil pump so keeping your crank full not allowing cylinder heads to bleed down or the check valve in the rear head. Should be an easy fix once you have time.
    JR03CHOPPER and TapioK like this.
  20. KnotSo
    KnotSo Admin
    Washington
    My oil cap came loose once on a ride into kali, looked the same...
    SCOTTx88 and HMAN like this.
