Not sure but they may have changed the number of plates. The Karata clutch packs went from 13 to 11, due to different material being used.Anyone who is familiar or has installed a Baker Open Primary.....
Is this the clutch pack that is included with the Baker Open Primary, or is it different? Seems to have only 11 plates (I realize the stack height is what matters).
Many thanks
That's when they went to the soft pull ball and rampI'm surprised they wouldn't go with the 9 plate system. The 12 plate was in early Big dogs and then later went to a 9 plate system to increase the Steel thickness due to warping.
Although the numbers don't matter like you said. All about that stack height
