Bleeding air out of front caliper
Discussion in 'Technical' started by No H2O, Jun 11, 2018.
  1. No H2O
    No H2O Active Member
    Supporting Member Full Member
    DC
    2004 Ridgeback, 2004 BMW R1150r, 2001 Fat Boy
    Mark
    The front caliper doesn't engage right away and there's not much stopping power.
    I figure there air in the line and I want to bleed the air out.
    I've reviewed How-to writeups and videos but just to make sure I do it right, here's the steps I'm planning on performing:
    1. Take the top off the reservoir and put a tarp or rag under it.
    Note that I already looked at this and there's a very shallow area holding the fluid and the the fluid quantity has barely risen to that level. Not sure how high the fluid level's supposed to be.
    2. Have a buddy (or the old lady) squeeze the brake lever a few times then hold it against the handgrip.
    3. Loosen the bleed bolt on the caliper so that water and air come out through the hose.
    4. Tighten the bleed bolt.
    5. Repeat 2-4 above until no more air comes out of the caliper.
    6. Fill the reservoir to capacity with DOT5.
    7. Tighten the reservoir back up.
    Sound right?
  2. pknowles
    virginia
    paul
    Go to advance auto and buy a 25 dollar power bleeder. QUICK AND EASY
    SCOTTx88, Reddickracing and HMAN like this.
  3. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
  4. Reddickracing
    Reddickracing Active Member
    Full Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    Power bleeder is the way but that way will work just takes longer. Rub your finger across the brake rotor, is there a wet film? Mine wasn't stopping good and had a wet film on rotor. Rebuilt caliper with new orings and works a lot better now. Front brakes are not the best anyway
    bdm7250 likes this.
  5. pknowles
    virginia
    paul
  6. SEAL-rider
    Del Mar, CA
    Spencer
    It might even work with the power bleeder. Better together.
    pknowles likes this.
  7. No H2O
    DC
    Mark
    I'll check for the wet film, I take it that'll be brake fluid leaking?
    I do notice a loud noise when I squeeze the front brake lever, sort of like a cow groaning.
    #7 No H2O, Jun 11, 2018
    Reddickracing likes this.
  8. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Full Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    check the pads sounds like they are worn.
  9. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Funny you say that, I think I may have used my rear brakes only a handful of times...ever..
    dentdude36, what? and Reddickracing like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #10 BWG56, Jun 12, 2018
    bdm7250 likes this.
  11. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    SCOTTx88, what? and pknowles like this.
  12. Reddickracing
    Full Member
    Louisiana
    Jeff
    Yea I agree, both my Harleys have awesome front stopping power but not the dog. Didn't say it was bad, it works and works good just not like my other bikes. Iv read several people on here say the front brakes are a lil inferior.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You can do it old school by yourself, right hand pump the brake and hold, left hand loosen and tighten, done.
  14. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    Last time I tried that stretch, I put the back out for a week -- buy the tool, you're body will thank you for it, maybe not today but eventually.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Its 41" on my Mastiff between the bleeder and the lever, add another 7" for a K9 making it 48". if you can't reach that far ya prolly shouldn't be riding a Dog anyway cause your feet won't touch the ground.:oldhardlaugh:
    On the other hand, no pun intended, most people prolly have a problem getting one hand to squeeze the lever and the other to turn the wrench anyway.:oldlaugh:
    SCOTTx88, Reddickracing and bdm7250 like this.
  16. bdm7250
    bdm7250 Guru
    Doug
    My slammer has six piston dual disc on the front and in my opinion it's no better than my mastiff, but then again I do ride like an old lady..:D
    BWG56 likes this.
  17. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I agree those speedbleeders I have it just takes longer when starting from scratch. Last time I did a brake job I put a regular bleeder in and got it started then used the power bleeder to finish it off. I couldn't get the speedbleeder to get it going. Honestly based on that I know people rant and rave about them but the speed is all in the name not the process.
    I'm thinking about changing them back and just using my pneumatic bleeder for a second instead
  18. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    Not really worried if it takes longer -- done right considering its the brakes is more important to me. I'm an old man -- I've got the time
    Mallito likes this.
  19. roadie1389
    roadie1389 Active Member
    Full Member
    Wylie, Texas
    Me: Hey babe, can you come here for a sec?
    Wife: What you need?
    Me: Here, pump the lever and hold it.
    Wife: Sure
    Me: Again.
    Wife: Good
    Me: (pat on the butt) Thanks babe.
    bdm7250 and Reddickracing like this.
  20. what?
    what? Active Member
    Full Member
    Central NJ
    2008 big dog pitbull
    Bill
