badyellowvette
Didn't even know I blew the release out. Found it in my driveway today. Engine didn't sound any different. I need a part number for an 2008 K9. Guess I will need the tool also. Thanks, Jim
Chuck (bdm7250) is in your neighborhood, he will send/loan you the tool. S&S compression release ya can find online for around $110ea. And Chucky just did a nice how to on replacing themDidn't even know I blew the release out. Found it in my driveway today. Engine didn't sound any different. I need a part number for an 2008 K9. Guess I will need the tool also. Thanks, Jim
http://www.bigdogbiker.com/threads/how-to-cr-replacement.81615/Could you post a picture of it and where it is on the bike? I'm not familiar with it and would like to check mine.
Thank you. I'm studying at the same time; I did an image search and didn't think to go look there.
He's only an hour above BuffaloThanks guys, I see Chucky is in Canada. I wonder how long it takes to get something mailed from Canada.
If I had time and a passport I'd drive up Buffalo is two and a half hours from me. I suppose I better find out if I can use his tool first.He's only an hour above Buffalo
He said if anyone needed it, he would send/loan it to them to use. If you have a motorcycle shop around you might be able to borrow one. The shop close to me that I fix Dogs for him when they come in loaned me his and he had never used it.If I had time and a passport I'd drive up Buffalo is two and a half hours from me. I suppose I better find out if I can use his tool first.
Sent him a message about the tool. Does anybody have part numbers for the rocker cover gasket kit?He said if anyone needed it, he would send/loan it to them to use. If you have a motorcycle shop around you might be able to borrow one. The shop close to me that I fix Dogs for him when they come in loaned me his and he had never used it.
90-4111Sent him a message about the tool. Does anybody have part numbers for the rocker cover gasket kit?
Here is a good deal. Cheaper than S&S sells them for..Didn't even know I blew the release out. Found it in my driveway today. Engine didn't sound any different. I need a part number for an 2008 K9. Guess I will need the tool also. Thanks, Jim
Tool is yours to use, PM'd you. I will mail out by the weekend..If I had time and a passport I'd drive up Buffalo is two and a half hours from me. I suppose I better find out if I can use his tool first.
https://www.jpcycles.com/product/42...t-kit?redirectedKeyword=423-946&totalResult=1Sent him a message about the tool. Does anybody have part numbers for the rocker cover gasket kit?
Ya don't need the wiring and connectors, its cheaper this wayHere is a good deal. Cheaper than S&S sells them for..
https://www.ebay.com/itm/S-S-Cycle-...Release-Kit-/323218639970?hash=item4b41550c62
Your a smart man..Ya don't need the wiring and connectors, its cheaper this way
https://www.ebay.com/p/S-S-Cycle-90-4914-Compression-Release-Assembly/171146941?iid=392037151662&_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=50543&meid=77fe76b29a5b4c21aee4f97e3435c845&pid=100005&rk=3&rkt=12&sd=192016969601&itm=392037151662&_trksid=p2047675.c100005.m1851
Maybe you might have one of those O-rings pinched. I didn't have any problem with them when I did mine but I did pay particular attention to seating them. Its very easy to check them unless 1 got cut with the top of the tube.I just changed both of mine out this past week. The front compression release came apart on my 08 Pitbull so I figured I might as well change both of them out. I would recommend that you go ahead and change out the pushrod O rings while you are at it. I didn’t and now I have an oil leak so I’ll be changing those this week. Also make sure you torque everything back to specs. I had my son make me the socket tool for the compression release and my wife who works for Lockheed Martin solder the wires together .
That's decent DougTool is yours to use, PM'd you. I will mail out by the weekend..
