My 07 Mastiff is blowing oil out the air filter. Has anyone experienced this?
Seems like it is doing it over 70 mph.
pics up soon:loony:
This sounds like the problem to me. My 03 had very bad blow-by but the newer models haven't had a record of this or not like the older models.check the oil level, i think this bike is checked "on the side stand" not up right, if done straight up oil is to high! Check the book!!!!!!!
I don't think I would go that far yet. Some blowby is expected on the exhaust pipe, battery cover, and misc. The only way to get rid of it completely is to run a hose to the ground. I am running a -12AN hose and breather system on my camaro. Crankcase pressure is perfectly normal side effect of an engine.Leak down test for sure. 05chop
Same thing here - my previous 107 was real bad - later I did a by-pass kit. The new 117 - zero drip from blow by.This sounds like the problem to me. My 03 had very bad blow-by but the newer models haven't had a record of this or not like the older models.
You oil tank has two tubes that stick up from the bottom where two oil lines come into. One is the vent and the other is the return from the oil filter. They stick up almost all the way to the top of the tank. Can't find an illustration of this but it's in the manual.
If you over fill your tank then oil is allowed to run down the vent line to the motor and can be spit out the breather. So, check to ensure you are not overfilling your tank.
Later,
Ray
