Bolt on opposite side of shift rod near transmission
Discussion in 'Technical' started by No H2O, Jun 12, 2018.
  1. No H2O
    No H2O Active Member
    DC
    2004 Ridgeback, 2004 BMW R1150r, 2001 Fat Boy
    Mark
    Probably not much of a contribution but the only change from stock that I've made thus far is on the tranny side the bolt that holds the shift rod threads in only one way.
    Since the shift rod itself has threads all the way through I figured get another bolt for the opposite side to make it tighter.
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I personally don't see this doing anything more than locktite would accomplish.
    If you really wanted to make sure it wouldn't move, the option will be drill a small hole perpendicular to the threads in the shifter lever and tap for a small set screw. But again will the forces on that rod under normal conditions that too seems like over kill.
    Have you had issues with the shift lever to the linkage?
  3. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Not to nit pick, but should have gone with a cap screw rather than hex head bolt, keep a consistent look... Also agree with Mike, a bit of overkill...:2cents:
    dentdude36 likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  5. No H2O
    DC
    Mark
    Perhaps it's purely peace of mind on my part that this makes me feel a little more secure, I've seen bolts come off (not on a BDM)
    I'm looking for a chrome cap screw, this was just to get me on the road asap
    bdm7250 and Unsprung like this.
  6. bdm7250
    bdm7250 Guru
    Doug
    Should be able to get what you're after at Fastenal.
  7. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    If that's the case I would recommend getting a longer bolt and using a nylon lock nut on the inside (near transmission) as that WILL hold the bolt better than another bolt screwed in from opposite side.
    While I had a bolt come loose on my shifter years ago (not my dog) that was probably my own fault for not locking it tight enough or no locktite.
    Luckily I had a spare and fixed it on the side of the road just outside DC. Zip ties will fix this in an emergency as well as other crap and you should carry them in your toolkit.
    what? likes this.
  8. what?
    what? Active Member
    Central NJ
    2008 big dog pitbull
    Bill
    i was under the impression the linkage should have a bit of play. like a ball and socket type fitting on either end. the nut should be good with locktite but the connection should not be truly rigid as there is movement during shifting (front and back). i did the extensions so the linkage rod was lengthened. shift linkage.jpg
  9. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    I think the original screw presses against the inner hub and the outer part float if you will which let the heim joint work properly
    what? likes this.
  10. what?
    what? Active Member
    Central NJ
    Bill
    heim joint. thanks but i did not know the term.
    In NoH20's case it looks like its sandwiched between two added washers. maybe its the picture but the washer looks like its right up against the land
  11. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    make sure to clean and re-lube the heim occasionally. they must stay free moving and in line with one another to eliminate binding.
    pknowles and bdm7250 like this.
  12. bdm7250
    bdm7250 Guru
    Doug
    I use a dry graphite spray a couple times a year, dirt wont stick to it like other lube's..
    pknowles likes this.
  13. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    that's why you use nylocks -- can get to stay where it is but not have to be tighten against something like using a lock washer.
  14. No H2O
    DC
    Mark
    I assume I can get said nylocks through Fastenal?
  15. dentdude36
    dentdude36 Banned
    Upstate NY (suburbs of Buffalo)
    2007 K9
    kevin
    Jmo but honestly I'd just run the way it was with original bolt and loctite I've never heard of or seen one come loose
    what? and bdm7250 like this.
  16. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Absolutely. Nyloc's are great things -- even get popular sizes at home depot, ace, lowes, Better selection at mcmaster-carr, fastenal and grainger.
    chubs likes this.
  17. what?
    what? Active Member
    Central NJ
    Bill
    maybe they dont want the loctite at the heim joints??? some guys will slop it on and it will ooze when you tighten the bolt/nut.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Ya got a point there:old2:
