brake pads that you sell for a 2010 K9
Discussion in 'Wild Steed Worx & Services' started by EMILIO, Mar 20, 2017.
  1. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    i want to know if the brake pads that you sell have alot of brake dust , im trying to minimize the amount of dust and are the front pads the same as the back? i looking to buy these today.
    chubs likes this.
  2. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2009 Sporty Trike Converted, 2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    #2 Little-Boo, Mar 21, 2017
    Srodden, Viking and chubs like this.
  3. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    so are you saying that " http://www.wildsteedworx.com/index....ath=65_68_173_74_273_320_322&products_id=1287 " is the answer to my question and these don't produce alot of brake dust , or are you just telling me the part that i need? i do know that the Lyndall's dont have much brake dust but i wanted to know that quality of the pads at WSW.
    chubs likes this.
  4. Little-Boo
    McAllen, Texas
    Carlos
    I use the Lyndall's because they don't produce alot of brake dust. They are Pricey but good. The others was just to let you know where you can get brake pads if you need some
    Carlos :old2:
    #4 Little-Boo, Mar 22, 2017
    chubs likes this.
  5. awg
    awg Well-Known Member
    2004 Big Dog Chopper
    There you go.
    chubs likes this.
  6. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    07' Mastiff, DOC's ESC, 585DualRunner, Spyder F3T
    Ker
    :agree::old2:
    Srodden, PacoPetty, bdm7250 and 2 others like this.
  7. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Srodden, chubs and BWG56 like this.
  8. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    Ker
    The way I ride, a lifetime:oldlaugh:
    chubs and bdm7250 like this.
  9. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I haven't found any pads that don't produce dust so I just wipe it off. Now, my truck did have pads that didn't produce dust but I had to replace the rotors all the time. So, pick your poison. For the Dog, replacing rotors isn't the way to go.
  10. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    I really don't understand this brake dust problem I never noticed any on mine, the back wheel will get some road dust on it but I wipe everything down after every ride, are you using brakes excessively? Possibly calipers sticking? Not braking soon enough and have to apply to much? Really just asking cuz I never notice brake dust ever oneither wheel
  11. bdm7250
    bdm7250 Guru
    Doug
    That's cause stopping power from your highway speeds of 15mph is fairly nonexistent...:moped:. :oldlaugh:
    chubs, Big D Florida and TapioK like this.
  12. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    Don't
    don't you need pop air smokes!? Go away:cry:
  13. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :agree::agree::agree: I also never notice much on my wheels, really it's the belt dust that is on the rear after I ride, not the brake dust.
    BWG56, Big D Florida and dentdude36 like this.
  14. bdm7250
    bdm7250 Guru
    Doug
    Yes I do, thanks for the reminder..:chopper:
  15. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
  16. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    Ker
    Yours are chrome and it slips right off:D
  17. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    I see customer's rides here all the time and I have to say that every time I see a rear dust issue its because the rider is large or rides two up allot and uses allot of brake power or they ride the rear brakes even though they swear up and down that they don't.
    It's not rocket science when you look at a rear rotor and it is worn ragged the buttons are loose and there is dust on everything and you look at the front rotor and it looks like it is barely used.
    chubs and cdogg556 like this.
  18. pauldeepsea
    pauldeepsea Well-Known Member
    California
    2004 Pitbull/ 2006 big bear sled 300
    Paul
    So let me ask the question? Any recommendations on type of brake pad material? Sintered, organic? I ride the shit out of the bike and brake pads tend to 1 make a mess and 2 wear quickly.
    Thanks,
    Paul
    chubs likes this.
  19. KaptinAmerika
    2006 Big Dog K9
    Curtis
    A good question indeed.
    Organic is always going to be the dirtiest pad you can put on your ride.
    Sintered will dust but not as much as organic.
    Ceramic is the way to go these days but even then I have found different issues with different ceramic pads.
    I've been running the ceramic Dura pads and to date there the best pad I have found.
    Relatively long lasting, depending on how you ride, lower heat factor and less dust.
    The dust is easy to wipe off with a little detailer and a clean cotton cloth.
    The next big issue I find is that allot of people don't understand what really needs to be done when they change their brake pads.
    Most simply yank their old pads out and throw the new pads in.
    Most do not:
    Surface the rotor, easy to do with a drill and a hand surface tool.
    Clean all the dust out thoroughly from the caliper using a good brake parts cleaner
    Use additional anti-squeal on the back of the pads
    Use proper, if any, high temp caliper grease where the pads ride and on the pad retaining pin
    Rebuild the caliper if needed, if your pads are wearing even a little uneven you have to rebuild the calipers
    Of course if your putting new rotors on the first is not needed.
    I am hoping to get a how to video out soon on brake pad replacement.
    I wish the company that was building the ceramic pads and discs was still in business.
    They claimed zero dusting and no molten on your rims.
    But they were so expensive no one was buying them.
  20. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    Ker
    I like these pads, I have hardly any dust problem
    chubs likes this.
