brake reed switch
Discussion in 'Help Wanted' started by dmouse, Mar 4, 2017.
  1. dmouse
    dmouse Member
    New Zealand
    2005 big dog mastiff
    Dave
    i know that i have asked for help with this before but i am still struggling to get out the small screw that holds in the reed switch i have tried everything to get out this screw apart from a drill but before i attack it with a drill does anyone have any ideas to get this out. i have tried the smallest screw drivers hex and torque drivers without any luck so please any realistic help please regards all
    dave
    chubs likes this.
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    something i saw somebody on one of the good car shows on TV the other day, use this at your own risk. small gauge wire that fits into the hole. when you know it fits, pull it out and put a SMALL dab of JB Weld on the end and re-insert it and let it set up, then use a pair of plyers to back it out. i would say the risk of this procedure is high, but.............
    chubs likes this.
  3. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    Is it stripped or you just have not found a hex to fit it?
    If the hex is stripped I would first recommend a small torx that is slightly larger than the hex gently tapped into the hex set screw.
    I do this frequently with stripped hex cap screws.
    If you use a drill bit only use a left hand bit and go at it super slow at first to make sure you drill into the set screw and not side wise into the aluminum.
    You can always go to the next set screw size up if anything goes wrong.
  4. chubs
    chubs Well-Known Member
    laf. indiana
    runky
    :hi: Something I have done to break loose those super tight set screws on pulleys, is find a couple allen wrenches of the correct size. Heat one up real good and hot and put it in the set screw. Let it heat the screw up and Gently wiggle it back and forth. Then take the cool wrench and try to back the screw out. The thinking is that the hot wrench heats the screw, causing it to expand ever so slightly, and when it cools the "bond" has been broken . I've had pretty good luck breaking set screws loose doing that. Worth a shot :yesnod:
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The heat would also break the loctite if it had any on it also. Good idear chubs:old2:
    Butch Cassidy and chubs like this.
  6. chubs
    laf. indiana
    runky
    Didn't think of that aspect ! Maybe my thinking was wrong !!
    BWG56 likes this.
  7. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    I think your right. Thats what I would do along with Kaptin's method.
    chubs likes this.
  8. dmouse
    dmouse Member
    New Zealand
    Dave
    the head of the hex is so badly damaged i can not get anything to grip to get it to turn i do not want to drill it as it might damage the whole dam thing i might have to get a whole new control or a used one if any one has one for sale and willing to ship it to New Zealand at my cost
    chubs likes this.
  9. bikeone
    bikeone Active Member
    Bavarian Forrest / Germany
    Big Dog Pit Bull / Suzuki 1100 Streetfighter
    Hans
    Heat the screw to break the loctite and use a left Hand drill as small as the Hex key - The screw will turn out without damage, Only screw will be destroyed.
    chubs likes this.
  10. dmouse
    dmouse Member
    New Zealand
    Dave
    ok i will give it a try thanks just need to go get a left hand drill bit to be honest i have never heard of left hand drill bits thanks
    chubs likes this.
  11. dmouse
    dmouse Member
    New Zealand
    Dave
    tried this and sadly it has not worked so i guess my best bet is to take it into a repair shop and have them sort it, or is there a way to rewire the reed switch so it comes on with the rear brake switch when i use the hand controller ???
    chubs likes this.
  12. chubs
    laf. indiana
    runky
    Sorry . But don't think so
  13. dmouse
    dmouse Member
    New Zealand
    Dave
    it cant be wired this way you mean ?
    chubs likes this.
  14. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Didn't really understood your question. That is exactly what reed switch does, it's the way to tell lever is pulled. Or are you saying the wire or wires from the reed switch are broken? The new part costs like $3 if I remember correct. Curtis has those, or you can buy them from net too. It is very common concept.
  15. chubs
    laf. indiana
    runky
    Maybe if you had a really small normally closed
    push button switch ( like how the lite switch in your refrigerator works) you "might" be able to rig up something
  16. dmouse
    dmouse Member
    New Zealand
    Dave
    the reed switch needs to be adjusted for it to work as my brake light is on all of the time but the screw that holds it in is damaged and i can not get it out i have tried drilling it out but its that small all i am doing is damaging the alloy around it
    chubs likes this.
  17. chubs
    laf. indiana
    runky
    That's using the old noggan !!!
  18. TapioK
    Tapio
    I WOULD NOT try to drill it out myself! Take it to shop! One hour fee is cheap, new hand control is expensive! There is time and place to fix your own bike, but do not practice with expensive parts.
    chubs, dentdude36 and bdm7250 like this.
  19. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :agree: But depends on your skill level, and what you have for tools.
    chubs, TapioK and dentdude36 like this.
  20. TapioK
    Tapio
    Would you have the needed skills, you would not ask these questions...
    chubs and bdm7250 like this.
