Brake System
Discussion in 'Technical' started by Raywood, Dec 21, 2009.
  1. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    For all 04 and above BD's. :D
    Big D Florida likes this.
  2. zipnz
    zipnz Active Member
    Grand Prairie, Texas
    2004 BDM Chopper DT
    Paul
    brakes
    Just curious, what happens if you were to use DOT 3 fluid?
  3. MARV
    MARV Well-Known Member
    CENTRAL JERSEY
    05 CHOP
    SUL
    it would coagulate
  4. zipnz
    zipnz Active Member
    2004 BDM Chopper DT
    Paul
    well, that explains it then. can I bleed out the "coagulated" fluid normally? My front brake is totally inop. feels hard a a brick when you squeeze the lever.:(
  5. V
    V Guru
    Would depend on the viscosity of the coagulation. :D
    Probabley not. My guess would be easier to take apart and clean it up. V
  6. MARV
    CENTRAL JERSEY
    05 CHOP
    SUL
    when i changed mine i took everything apart. caliper, resevoir, line. washed all metal parts in brake cleaner and any rubber and plastics with soap and water. dry with compressed air. then soak all parts in the fluid your gonna use. then install and fill.
    a pain in the ass but hey its winter
  7. ourode12
    ourode12 Member
    Piedmont, SD
    04 Ridgeback, 68 Triumph Bonnieville, 92 shadow 1100, 2012 Harley Street Glide
    Thomas
    I can't get the front brake handle to show any pump action. I tried to bleed the line but there is absolutely no pump action, In or out. Is that what you're talking about by coagulation? Do I have some blockage or something in the handlebar assembly? The fluid won't even pump out of the handle assembly.
  8. standuprick
    standuprick Active Member
    Cleveland, Ohio
    06 Ironhorse Legend
    You migh have air in your master. Takes awhile to bleed them
  9. isben22
    isben22 New Member
    2005 K9
    Rear Break Sensor
    I just bought a used 06 K9 that needs some minor love. As I wait for the service manuals... can anyone provide me information on the rear break sensor? I need to replace it (wires are frayed and break lights won't work). as neither front nor rear actions will trigger breaklights...I think I have a bigger problem.
    Can anyone suggest a part number, replacement oart/work around...old tractor part...or part specifications such as thread type, voltage etc?
    I slso read about some magnets reed sensors that fail and am trying to get my mind wrapped around that subsystem.
    Any help/ experience would be great!
    R
  10. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Check THIS out too. :up:
    SCOTTx88 likes this.
  11. upstatedak
    upstatedak New Member
    mastift
    having problems with my rear brake caliper on my 06 Mastiff seems to be sticking a little how can I tell if it's the caliper or the master that needs rebuilding
  12. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Is the plunger on the master retracting? Is the piston on the caliper retracting?
    That should answer your question once you determine which is.
  13. upstatedak
    mastift
    thanks will check it out
  14. tbonelynch
    tbonelynch New Member
    Atlanta
    2006 Ultra Classic, 2004 BDC
    Tom
    Inside your master cylinder, there is a tiny port that relieves the line pressure, back to the reservoir. If your plunger (master cylinder piston), does not spring back completely, it will block this port, and keep the pressure on the calipers. Also, this port will get blocked by dirt in your fluid. Change your fluid, every other year to keep things clean inside. Brakes are more important than horsepower. Ride safe.
  15. tbonelynch
    Atlanta
    Tom
    Also, I had a caliper issue, years ago. The O-rings around the pistons, had accumulated so much dirt in the groove that they sit in, that it wouldn't allow the pistons to retract. Thus, dragging the pads, causing heat that expands the fluid, causing more brake pressure. I had to use the brake pressure, to pop the piston out of the caliper, with the pads removed. I just cleaned the caliper and piston, and re-used my O-rings (because I wanted to ride that day) and it worked fine. I was in high school at the time, and that is when I learned "why you should change your fluid".
  16. upstatedak
    mastift
    thanks I'll get in there and see what I find
  17. ZeDevil
    ZeDevil Member
    Bucharest, ROMANIA
    '03 Chopper / RT
    David
    Anyone knows what rebuild kit works on the 2003 Chopper REAR master cylinder? The plunger is not fully retracting, I guess it's rebuild time. Only changed the fluid in all these years.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    DOC has them, Dead One Customs
    SCOTTx88 and bdm7250 like this.
  19. ZeDevil
    ZeDevil Member
    Bucharest, ROMANIA
    '03 Chopper / RT
    David
    Thanks guys, but I'm on the other side of the map and I would pay more for the shipping than the part itself, that's why I'm trying to find out some part numbers to cross-reference and find a seller here in Europe :)
    I was thinking this master cylinder should be similar to harley evo style but what model? softail maybe?
    Anyone in Europe rebuilt their rear master cylinder lately? if ever? :oldhardlaugh:
    BWG56 likes this.
  20. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    A Harley kit will work. The key is the bore size. I know if you search it's been covered in here a few times.
    5/8" bore is for 04 and newer, front and rear.
    You might want to double check yours but it might be 3/4" bore on the rear.
    Should cost ya all of $15-20
    ZeDevil and chubs like this.
