Broken swingarm!!
Discussion in 'General' started by NZBigDog, May 31, 2014.
  1. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    Well....went for a ride around town today and was thinking bike felt abit strange....when I got back to the workshop I was checking out the shocks and found my swingarm is broken (not just cracked). It may have been cracked for a while and now has broken right through just next to where the shock mount is. :(:(Has anyone else had this?
    I have stripped the back this arvo (only took 30min to get the swingarm out) and I am hoping someone can replace that part off the swingarm or maybe cut it and put a stronger piece of pipe inside the current one.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    hows about a couple pics?
    cdogg556 and SCOTTx88 like this.
  3. Bowhunter
    Bowhunter Well-Known Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    Glad it did not cause you to wreck.
    SCOTTx88 likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Damn, good you weren't hurt
  5. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    blowery just had a broken swing arm on a 02 Mastiff as well.....interesting....
  6. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
  7. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    That could have been bad....glad you caught it
  8. SCOTTx88
    SCOTTx88 Active Member
    Fredericksburg,Va.
    2004 Mastiff (Minus EHC)
    Scott
  9. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Wow, thats not good! Glad that you found that...:eek: You might want to call Bigdogpartsking @ 620-257-2009 they might have one laying around...
  10. blowery
    blowery Member
    02 Mastiff
    WOW,just had the same thing happen on my 02 mastiff,broke clean thru in the same spot.
  11. spadesluck
    spadesluck Active Member
    New Mexico
    05 Chopper DT
    Jason
    How the hell does that happen? Looks like someone took a sawzall to it!
  12. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    This is also a 02 Mastiff.....what did you end up doing??
  13. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    I was riding around town with my 12y/o daughter on the back yesterday when i found this!!
    I only weight 85kg and she is only 37kg so weight is not the problem.
    I hit a couple of good potholes on the last rally i went on so maybe that, but really this doesnt have "push" forces on it, it has "pull" forces. Maybe a shock has "jammed"...but then if anything it should pull the actual shock mount off.
  14. gabe
    gabe Active Member
    holts summit mo
    2004 Bulldog
    Wow scary. Good catch though. I would think your idea of someone beefing up and rewelding would work if you can't find a replacement.
  15. blowery
    blowery Member
    02 Mastiff
    Havent done anything yet,I'm currently looking for a replacement swing arm,looks like mine has been cracked for a while and finally broke into,I'm a pretty big guy(250 lbs)and the roads in North Dakota aren't the smoothest in the world,while I'm at it I think I'll replace the shocks with a new set from wildsteedworx.Havent had the bike long and the previous owner was much larger than me,so no telling how long it's been cracked.
  16. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    I wont be looking for a replacement, it would way to much to get it to New Zealand.
    Its not too hard to make up a jig to hold the frame in some of the bolt locations and then cut this piece out and replace it.
    I have also emailed Rolling Thunder to check if they know why this area would be under stress on these older frames.
  17. blowery
    blowery Member
    02 Mastiff
    please let me know what you find out,should you change your mind bdpartsking thinks he may have these swingarms,but I agree with you,it wouldn't take much to repair the original,I used to cut and extend them all the time back in my dragstrip days,would actually be stronger than the original,good luck!
  18. blowery
    blowery Member
    02 Mastiff
    Here is a pic of the break,sorry for the bad photography but I haven't removed the swingarm yet,kind of hard to get to while still on the bike.
  19. NZBigDog
    NZBigDog Member
    Rotorua, NZ
    2002 Mastiff
    Jas
    Its real easy to get it off, only took me 40min from when i parked the bike in the shed until i had it all stripped and on the bench:2thumbs:
  20. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Shite!!!! :eek:
