Bulldog inverted forks
Discussion in 'Forks / Handlebars' started by dentdude36, Jun 30, 2017.
  1. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    I'm interested in putting the inverted forks on my 06 pitbull and before I contact Donna and Derek to check parts availability... I would like to know what is all involved in this besides the forks and top tree,,,, will my fender mount work? And does the lower tree need changed out or is it the same? Thanks for any input
    bdm7250 and chubs like this.
  2. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    07 bulldog forks are a bigger size. Derek is probably your best source for info
  3. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Kevin, both triple clamps will need to be changed, not sure but I think the fenders were wider on the bulldogs so you'll probably need to either modify yours or get a new fender and mounts also, personally I hated my inverted forks on my bulldog, they were rough as he'll compared to my forks on my mastiff, inverted forks look cool but that's it.
  4. pknowles
    virginia
    paul
    What's on the front of the pit bull now.. the 07 bulldog and Mastiff had the 21x3.5 I believe.
    chubs and cdogg556 like this.
  5. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    That's what I was wondering cause he may have to go with a wider rim to fit the fender, it's probably a 21x3.5 rim on the pitbull though.
    TapioK and chubs like this.
  6. pknowles
    virginia
    paul
    He'll need to get the bulldog fender mounts.
  7. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :yesnod: :old2:
    chubs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I was reading some old posts from Andrew and the inverted forks used 10w oil instead of the 30w. That has a lot to do with the ride, and prolly different springs
    cdogg556, bdm7250 and chubs like this.
  9. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    That's also in the manual. The inverted forks should be a good ride. There's a reason why all race bikes use it....
    What i don't know is what is the rake in the trees on the bulldog? Same as the Pit?
    chubs likes this.
  10. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    Yes the pitbull has 21x3.5 already and the new wheels I got are the same size so I may just need the fender mount
  11. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Yea, that is a good possibility, the dude I bought it from was a BWG! :oldsmile: :oldlaugh:
    chubs, BWG56 and dentdude36 like this.
  12. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    chubs, BWG56 and cdogg556 like this.
  13. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    chubs likes this.
  14. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Damn, they got some bad ass front ends! :old2: I want the 50mm forks! :drool: Oh well, I'll just add it to my wish list! :oldsmile:
    chubs likes this.
  15. Th3InfamousI
    Texas
    I know mean street is out of business.
    Skogdog has a set on his k9 they look great but you can't get them anymore unfortunately.
    Now don't let that stop you really all you need is internals for wearable parts and I imagine the bulldog uses some generic size springs and seals when it comes time to replace.
    chubs likes this.
  16. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    That sucks ass cause I just noticed last week that my hardly buddies have 50mm forks on their bikes! Our 44mm look like toothpicks next to the 50mm! I was thinking a set of 50mm would really beef up the front end.
    chubs likes this.
  17. Th3InfamousI
    Texas
    American Suspension is still around they make a 53 mm inverted front end.
    Bettet have deep pockets tho
    chubs likes this.
  18. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Yea well that can go on my "wish list" for later!
    chubs likes this.
