Charging stator /rotor issue
Discussion in 'General' started by Jwooky, Oct 12, 2017.
  1. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Bike was not charging. Checked for AC voltage at stator and it was 0.
    Replaced the stator with new compufire stator and checked for AC voltage at stator and it was still zero. . WTF?
    Can rotors go bad? Their is nothing left??
    The rotor was still magnetic. I don’t get it.
  2. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg,Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    I had a rotor fail and had to replace it in Dallas. Lucky I made it to Stroker's and they had one in stock. The bike ('08 K9) had about 60K miles at the time. Mine still had magnetic too, but it was bad--never did figure it all out. But it's been flawless since.
    It has all taught me that it wants a new battery every year...regardless.
  3. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Hard to understand. Have never heard of one going bad. What could go wrong? Magnets get weak? How do you test for that?
  4. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    must have a block, still not seeing it.
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    The magnets do wear down. If the magnet gets worn down over time and when the distance is too much it won't allow for the electricity to generate.
    In Rick's example above I was at Strokers and his magnet was very well worn. It was the OEM rotor and Id say it probably only had about 50% of the height of the magnet when compared to the new one.
  6. 07bigdog
    07bigdog 07BIGDOG
    Winnipeg,Manitoba, Canada
    07 k9
    Ken
    I also had a stator failure. As soon as the bike got warm, it would shut down. Let it cool off, and would start right up. Put everything back together and same problem. Changed rotor and all good.
  7. Th3InfamousI
    Texas
    That's rather an odd one...seems something else at play but won't argue with what worked for you.
  8. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll
    Carl
    ?? how does the magnet wear ? there is no contact,just spins in the air.
    maybe if a foreign object got in the air gap ?
    Jwooky and chubs like this.
  9. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    ^^my thoughts too?
    Anyone know what the thickness should be?
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #10 BWG56, Oct 12, 2017
    TapioK likes this.
  11. Th3InfamousI
    Texas
    Heat too..
    Also it's very possible that your new stator isn't sized to the rotor right. Meaning the air gap between the two is too large. Your new stator may be a bit smaller than OEM, and subsequently the matching rotor to your stator would be slightly thicker?
    There is varying sizes cause manufacturer want you to buy both parts!
    #11 Th3InfamousI, Oct 12, 2017
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #12 BWG56, Oct 12, 2017
    dentdude36 likes this.
  13. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Magnetic fields are effected by heat -- this scenario makes perfect sense.
    Personally, If I have to replace a rotor or stator I do them as a SET, it's almost always a better bet.
    SKOGDOG likes this.
  14. Th3InfamousI
    Texas
    Why would even a bad stator make the bike quit running? You can unplug it and it will still run, until you drain the battery. But that means it was never working in the first place.
  15. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    DIdn't by chance get a 38A stator vs the 32A -- I know the stator/rotor combo for the 38A compufire is a little different dimensions than stock -- vaguely remember a note about space in the install instructions.
    As more posts have said -- paired is always a safer bet.
  16. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Well, if the regulator was damaged at the same time (in an odd method) or a really bad design and it was placing a LOAD on the electrical system you can create that failure. With our bikes EHC being soo sensitive to voltage levels its not beyond the realm of possibilities.
  17. heybaylor
    East Texas
    Carl
    Hmm, guess I now have another maintenance item, clean magnets every primary oil change
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    #18 BWG56, Oct 12, 2017
  19. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    So after some research, talking to Curtis@WSW @KaptinAmerika the BDM stator and rotor is a proprietary 24 coil design. The aftermarket/Harley is 12 coil.
    The 12 coil rotor is larger diameter than the 24 BDM.
    Looking into if it’s possible to grind out the primary to accept the 12 coil rotor. Curtis said he has done it many times so I believe it to be true. I will,update when I have an opportunity to do so.
    BDM 24 coil stator
    Compufire aftermarket/Harley Stator
    Compufire aftermarket/Harley Rotor on left, BDM on right.
  20. Th3InfamousI
    Texas
    Just gotta grind the bosses off the inner primary not too bad a job.
