Charging stator /rotor issue
Discussion in 'General' started by Jwooky, Oct 12, 2017.
  1. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Please educate me, what is the benefit of having 24 coils? Or is it again just a Big Dog trying to fuck us with genius design
    BWG56 and chubs like this.
  2. chubs
    chubs Well-Known Member
    indiana
    2002 pitbull Prostreet --
    runky
    The one machine I designed on has more than 2 billion (not a typo), cycles on it and still running, how kool is that:old2:[/QUOTE]
    Is that the same tool ya used to remove the paint saver ? I believe old Og invented that several years back, while he was sitting out front of his cave, trying to come up with a device to clobber those pesky dinosaurs over the head with.!!
  3. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    I am. I have a bunch of pics for the conversion I will post later.
    I got a little disinterested with all the nonsense banter that was hijacking the post.
    chubs likes this.
  4. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Here are the pics to convert to a “Harley Style” rotor and stator. Note you must use both matching rotor and stator because BDM is a 24 coil and Harley 12 coil.
    First note the diameter difference. (BDM is smaller)
    The inner primary has some bosses added for no good reason. (Hmmm)
    I used an air grinder to remove the material. I covered everything I could with foil so it would not get shavings all over chain etc.
    Here is the result.
    One final note. The BDM Rotor is thicker.
    Now Harley
    Fortunately the Rotor came with a spacer that would compensate for the difference. Just be mindful of that if you convert.
    #24 Jwooky, Mar 4, 2018
    Reddickracing likes this.
  5. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    #25 Jwooky, Mar 4, 2018
    Reddickracing, Srodden and SKOGDOG like this.
  6. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    yep probably right that nut backs off and there goes the rotor teeth.
    Jwooky likes this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good question vs the 12
    TapioK likes this.
  8. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    I cannot get the Photo Bucket pics to work, but here is Jake's step by step on how to install the 40 Amp compufire stator system. I ordered the same kit and replaced mine years ago and it was easy to do.
    http://www.bigdogbiker.com/posts/115144/
    Carlos :old2:
