Chrome Repair
Discussion in 'General' started by lonerider101, Mar 14, 2019.
  1. lonerider101
    lonerider101 Member
    1972 1000cc Harley XLCH Sportster, 1986 Harley Wide Glide, 2005 Big Dog Chopper
    I hav chrome bubbling/flaking in a cpl hard areas - top of inner primary & top of right transmission door on my '05 Chopper. Does anyone know of a repair method as this will be a major tear down? Also has anyone used Caswell's 'Plug N' Plate' Electroplating Chrome to repair parts - ebay listing. Manufacturer says will work & stay but will hav a fine hair line where meets/overlaps existing chrome. All ideas & info is appreciated. Thanks
    Michael rogers likes this.
  2. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Only method I know is to strip and rechrome the entire part.
    SCOTTx88, LHS and chubs like this.
  3. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    Agree with ya on that. The "plug and plate" stuff would be the same as spraying paint over rust blistered paint. The finish will only be as good as the layer underneath it.
    LHS likes this.
  4. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Yeah... no cutting corners on chrome plating.. got to have it actually acid bathed, sand blasted etc... good luck
    chubs likes this.
  5. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    The inner primary may just be cheaper to buy a used one as stripping and plating will be expensive.
    The trans doors are rare used and very expensive new so re-plate is the best option there just make sure they mask it correctly so you don't lose tolerance in the pressed bearing areas or end up with chrome where you don't want it.
    chubs and bigkelk9 like this.
  6. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Yea, I just had my outer primary cover done, and I think it would have been cheaper to just buy a new one.
  7. lonerider101
    lonerider101 Member
    Thanks guys I appreciate yur info and input.
  8. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    There is a Harley aftermarket company out there, that sell this kind of stuff cheap. When I get to my shop, I'll text you the name. I have a catalog somewhere.
  9. lonerider101
    lonerider101 Member
    Great - Thanks
  10. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I thought I had talked to you before and had your number, but I guess I don't, so here it is, in case anybody else wants it to.
  11. lonerider101
    lonerider101 Member
