Clutch cable
Discussion in 'Help Wanted' started by bigkelk9, Mar 5, 2017.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The only thing I would add to those instructions is that sometimes the 1/4" back off might be too much if your bike wants to creep when the clutch is pulled in, and if it does, you might want to lessen the 1/4" to 1/8" or 1/16"
    chubs, bigkelk9 and bdm7250 like this.
  2. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Eric is talking about the clutch nut, the jamb nut is what you had your hands on this morning, two different things. What I posted is how to adjust your clutch, if I were you I would take Ker up on his offer to talk you through it.
    chubs, TapioK, Unsprung and 1 other person like this.
  3. bdm7250
    bdm7250 Guru
    Doug
    :agree:
    chubs and bigkelk9 like this.
  4. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Just got off the phone with Ker, bout to take my cover off because I have no play on my chain when applying my clutch and pulling the plug out revealed some metal shrapnel.. 20170305_104216.jpg
    chubs, cdogg556 and bdm7250 like this.
  5. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    That looks like just a little more than normal, keep us posted......:old2:
  6. bigkelk9
    07 big dog k9
    Kel
    Took cover off.. everything looks good.. no visual chipping away of gears or n e thing like that.. there is however about a little under a quarter inch of play in the gear with the clutch adjustment out
    chubs likes this.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Play in the gear? What ya mean?
  8. bigkelk9
    07 big dog k9
    Kel
    So.. my nut as Eric was stating was loose, I'm gunna get with Donna and get the new updated hardened nut and washer update.. the adjustment with the rod being flush with the jam nut is what got me as to why I posted this, glad I didn't ride with it like this.. could a been a bad outcome when that nut finally came off.. a personal thanks to all of u who chimed and and an extra thanks to Ker for spending the time with me on the phone and getting to know him a bit better!! 20170305_111104.jpg
    cdogg556, chubs, Stone and 5 others like this.
  9. Th3InfamousI
    Texas
    Is that transmission oil leaking?
    How loose was it?like spin it with fingers?
  10. bigkelk9
    07 big dog k9
    Kel
    chubs likes this.
  11. Th3InfamousI
    Texas
    Yep been there with fingers for tight...kinda scary. That's why I said red loctite and 150 lbs earlier. If I buy another Big Dog I won't ride it until I take it off and retorque that nut specifically.
    I was referring to what ever is that redish liquid around the nut.
    Behind that clutch basket is a transmission seal while you got it apart already might want to take a peak at it. And you can check if any play in the transmission shaft.
    cdogg556, chubs and bigkelk9 like this.
  12. bigkelk9
    07 big dog k9
    Kel
    Yeah, I was kinda thinkin about that.. will do.. good lookin out Eric
    chubs and Unsprung like this.
  13. bigkelk9
    07 big dog k9
    Kel
    The easy pull clutch ramp clutch plate.. anyone know anything about these.. Donna is supposed to be calling me back shortly and I wanna make sure I'm on the same page and it's worth the buy
    chubs likes this.
  14. bigkelk9
    07 big dog k9
    Kel
    Anyone have one on their bike that can tell me where they got it and what they think
    chubs likes this.
  15. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Ker has one in his
    chubs, bdm7250 and bigkelk9 like this.
  16. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    Maybe baker would have it just a suggestion
  17. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Not sure if knowing Ker better is actually good for you, great you found the problem and did catch your nut before it fell off.
    chubs, BC200742, bdm7250 and 2 others like this.
  18. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    :oldhardlaugh:
  19. TapioK
    Tapio
    What year did easy pull come standard? I think you may have one already? I thought all the bikes have it from -06 or something??
    chubs, dentdude36 and bigkelk9 like this.
  20. bigkelk9
    07 big dog k9
    Kel
    I hope mine isnt what they feel like.. someone posted something about em a while back and showed pictures to compare em and mine looks like the older style.. mine is an 07
