Clutch Parts -- Used and new
Discussion in 'Swap Meet' started by Jersey Big Mike, Jul 1, 2018.
  1. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Had an issue with my 08 K-9 a while back and suspected the clutch (wrongly) so I replaced it with a Bandit.
    I have most of the old clutch setup (missing a few bolts that are easily available) and needs a new throwout bearing.
    It's the original carrier from Baker but there no cracks to be seen. Part 30 in manual
    I have at least 1 extra Inner hub part 20
    The Flanged Hub part 21 is good, but before using it I would replace the bearing in part 30
    30 and 21 are together and I can't get the retaining ring off personally so they'll need to stay together.
    I'll link to some pics when I can but I am having trouble posting pics on the site still.
    All reasonable offers will be considered -- trying to clean up the shed some more.
    Clutch was pulled at 22K I believe or there abouts.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    How do you like the Bandit clutch Mike? You notice any difference in the lever pull effort?
  3. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    I like it enough that this is the second one I've installed -- second K-9. Well for me I do feel its a little lighter but I have it set to add some force so it doesn't slip on me -- I'm 300lbs and I ride 2 up a lot so the light settting doesn't work as well for me as it might for others.
    It's a great value -- the price is right.
