Clutch Problem?
Discussion in 'Technical' started by BrianLo, Feb 11, 2009.
  1. BrianLo
    BrianLo Active Member
    Mission, TX
    2008 Big Dog K-9
    Brian
    Was pulling out from a gas station and as I shifted from 2nd to 3rd I heard a clunk followed by the ugly sound of heavy drive belt rub. I pulled over and the outer edge of the drive belt was worn, the clutch cable is looser than normal, belt also touches tire now. In neutral, if I push the dog back, it feels like the belt is slipping on the forward sprocket. just grabbing a bite to eat before I go out and pull the exhaust and clutch to see what's going on... wish me luck! :bang:
  2. Moespeeds
    Moespeeds Well-Known Member
    Cherry Hill, NJ
    2004 Big Dog Chopper, 2011? Redneck Monoshock, 2003 Roadstar Midnight, 2000 Roadstar Custom
    I'd say that's gotta be the drive pulley coming loose from the tranny?
  3. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    My drive pully came loose years ago and I recognized it when I backed the bike out of the garage every morning. The Tranny sprocket nut is locked in with a couple of hex bolts but somehow they wore and caused the nut to come loose.
    Let us know what you found out.
  4. Gas Man
    Gas Man Cool isn't cheap
    Calendar Participant Supporting Member
    Metro Detoilet
    But Ray would that effect the clutch? I wouldn't think so...
  5. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    No, wouldn't think so but it would cause the other issues he stated with the belt rubbing the tire the backing up issue he stated. Same problem as I had.
    With the 08 he may have the loose clutch nut that many experience with this year of bike.
  6. Gas Man
    Metro Detoilet
    Yeah that's what i was getting at... multiple issues maybe
  7. BrianLo
    Mission, TX
    2008 Big Dog K-9
    Brian
    :bang: :bang: :bang:
    You won't believe this... Found the problem, it seems the bolt for my sissy bar fell out, and got pulled into the front drive pulley. Chewed the belt pretty good and wore an ugly groove in the pulley. I used plenty of loctite when I installed the sissy bar, and as my luck would have it, the bolt didn't just bounce and hit the ground. Guess I need to order a belt and a pulley... will post pics soon.
  8. Nomad2day
    Nomad2day Longhair Redneck Geek
    Clarksville TN
    Gone but not forgotten 07 Bulldog, Now a 1966 Harley Davidson FL Electra Glide
    Neil
    Ouch....
    That bolt was pretty bad for being a sissy bolt.......:roll:
  9. BrianLo
    Mission, TX
    2008 Big Dog K-9
    Brian
    :roll: What's killing me is that it was 90 degrees and sunny here today... :bang:
  10. BrianLo
    Mission, TX
    2008 Big Dog K-9
    Brian
    pics...
    the culprit... belt shreds still attached
  11. N8KAM
    N8KAM Well-Known Member
    S.E Michigan
    05 Mastiff 07 Ultraclassic/Electraglide
    John
  12. Gas Man
    Metro Detoilet
  13. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    I install a 12" sissybar on occasion and use a clear piece of heavy adhesive tape to cover the bottom of the fender strut to keep the bolt from falling out if it loosens.
    #13 BigDogBro1, Feb 14, 2009
  14. Gas Man
    Metro Detoilet
    Sounds like Seats expierence hit a little too close to home for you.
  15. CURDOG
    CURDOG Active Member
    Sebring, Fl.
    2008 K9
    Loose Clutch Nut?
    I don't want to hijack this thread but this is the first I seen of a known problem with '08 models having loose clutch nuts. I just checked my belt and it's right on my rear tire. No sign of rubbing yet, but......
    Anyone else having this problem? :confused:
  16. PurpleDog
    PurpleDog Well-Known Member
    Raleigh, NC
    '07 K-9; '09 Coyote
    Jim
    Belt runs real close to the tire normally jj. close tolerance there bro. :up:
  17. CURDOG
    Sebring, Fl.
    2008 K9
    I just tried to slide a business card between and it's closer than the width of the business card. Ray mentioned a known problem with '08's having clutch nut problems and tire rub. With Daytona coming I'd rather fix any known problem so I can have some worry-free ridin.
  18. snake1962
    snake1962 Active Member
    Sumter, SC
    2008 K9 & 2004 HD V-Rod & Wife's Sporty
    Don't know if this happened with your sissy bar, but I also have a 2008 K9 and purchased the 12 inch as well. Sissy bar shipped with bike - not installed, so I installed. The sissy bar's milling was about a qtr inch to shallow for the bolts that came with the kit, they would never seat deep enough. Had to go to a hardware store and buy some hardened hex bolts to replace. I'll do the clear tape trick today as well.
  19. CURDOG
    Sebring, Fl.
    2008 K9
    I bought my sissy bar at the same time I purchase my bike but I installed it myself. I only use it when my wife rides so I take it off and put it on regularly. The bolts have lock washers on them and I snug them down and haven't ever noticed them working loose, even a little.
  20. PurpleDog
    Raleigh, NC
    '07 K-9; '09 Coyote
    Jim
    Ah, well mine will certainly get a credit card. I currently measuring .105 with ~3k mile Avon. I'm trying to find the specs in the service manual for us; but unfortunately I'm not seeing it JJ.
    {I think it used to run closer though when I had the previous tire on it; not so much because of tire difference but because of where belt shifted on front pulley a little maybe. don't think dealer aligned it correctly honestly - why I was asking on here before}
    #20 PurpleDog, Feb 15, 2009
