Clutch problems
Discussion in 'General' started by Michael rogers, Oct 5, 2017.
  1. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    red loctite absolutely, it's a critical component that you never see.....20 ft/lbs
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    If your hub and bearing are good I might be able to save you some coin on replacing it, I have a back plate PM me if your interested.
  3. Michael rogers
    Massachusetts
    Mike
    Thank you
    Sent from my SM-N920P using Tapatalk
  4. Michael rogers
    Massachusetts
    Mike
    Thank you ill let you know
  5. Forsaken
    Forsaken Active Member
    Southwest Florida
    2005 Big Dog Chopper
    Gil
    Well, we know he doesn't believe in loctite... I wonder if he owns a torque wrench. Strip it... rebuild it.
    dentdude36 and Michael rogers like this.
  6. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Holy fuk'n shit! Hope you threads aren't screwed up! :oldwtf: Glad you figured it out though. :old2:
    Michael rogers and dentdude36 like this.
  7. Forsaken
    Southwest Florida
    Gil
    Paul, I love that hardcopy manual... where can I get one???
  8. Michael rogers
    Massachusetts
    Mike
    Threads seem ok
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The threads are part of the Outer Hub with basket, he only needs the bearing carrier and not the whole Carrier Assembly unless the Flanged hub and bearing are bad.
  10. Michael rogers
    Massachusetts
    Mike
    Everything else seemed good .i hopefully only have to replace that one thing
  11. Michael rogers
    Massachusetts
    Mike
    Not sure if this sounds crazy but i need one clutch plate .When my clutch came apart one clutch plate now looks like a saw blade
