oldcarsarecool
Need help on clutch. Had problem with clutch not working on 07 Mastiff. Looked on here and found out it's my clutch hub nut was loose. Ordered new nut. washer, throwout bearing from Curtis. Started putting everything back together and now have a problem with pushrod. The jam nut is rounded off and the allen fitting in rod is stripped. It was bad before I started messing with it and now it's really bad. How can I get this rod out to replace it? Will start by taking off exhaust tomorrow but then what? Will taking off pulley cover be possible with rod still in ? I did slack out the clutch cable before starting to loosen rod Any help would be greatly appreciated
