Clutch
Discussion in 'Technical' started by chop it, Jul 11, 2018.
  1. chop it
    chop it New Member
    US
    With the bike up on a lift and the clutch lever pulled in while the engine is running the wheel turns. Does this mean that the clutch needs adjustments? Don't notice any pulling when on the ground. Thx
    Sent from my SM-G950U using Tapatalk
  2. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Nope, in wet clutch there is some drag from oil between the plates. I suppose the bike doesn’t jump when you go from neutral to first gear...
    chop it likes this.
  3. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    No, you don't need to adjust.
    Check THIS out. :oldthumbsup:
    :chopper:
    chop it likes this.
  4. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    Nope you're oil is cold and there is drag on the plates. Get it off the lift and ride it.
    chop it and pknowles like this.
  5. chop it
    chop it New Member
    US
    Thx
